KC868-A8 and PCF8574 Interrupt pin
#12
With Interrupt pin you can verify at each moment during the loop the pressure of a fluid (with analog meter).
If that pressure is higher than a maximum tolerated value, the sketch must be stopped immediately because damage will occur.
I use now IDE version 1.18.19.
Is it possible witch V1.5?
The control must be done continiously from the begin of the loop until the end.
I don't know the code for it and I do not find codes nearby.
Thanks
KC868-A8 and PCF8574 Interrupt pin - by andhol - 05-31-2022, 07:53 PM
RE: KC868-A8 and PCF8574 Interrupt pin - by admin - 06-01-2022, 12:13 AM
RE: KC868-A8 and PCF8574 Interrupt pin - by PMGO - 02-20-2024, 02:49 PM
RE: KC868-A8 and PCF8574 Interrupt pin - by admin - 02-21-2024, 12:43 AM
RE: KC868-A8 and PCF8574 Interrupt pin - by admin - 09-08-2024, 11:27 AM
RE: KC868-A8 and PCF8574 Interrupt pin - by admin - 09-09-2024, 11:13 PM
RE: KC868-A8 and PCF8574 Interrupt pin - by GVDC - 09-11-2024, 09:40 AM
RE: KC868-A8 and PCF8574 Interrupt pin - by admin - 09-11-2024, 10:38 AM
RE: KC868-A8 and PCF8574 Interrupt pin - by GVDC - 09-11-2024, 11:20 AM
RE: KC868-A8 and PCF8574 Interrupt pin - by admin - 09-11-2024, 12:15 PM
