[arduino code examples for A32 Pro]-12 How to use DHT11 temperature humidity sensor
*  Made by KinCony IoT: https://www.kincony.com
*  This program reads temperature and humidity values from a DHT11 sensor
*  connected to GPIO2 of an ESP32 board, and prints the readings to the serial monitor.
*  The DHT11 sensor measures the relative humidity and temperature in the environment.
*  This data is then read by the ESP32 and displayed in the serial monitor.
*  Requirements:
*  - ESP32 microcontroller
*  - DHT11 temperature and humidity sensor
*  - DHT sensor library by Adafruit (Install in Arduino IDE)
*  Connections:
*  - DHT11 Data Pin -> GPIO2 on ESP32
*  - DHT11 VCC Pin -> 3.3V on ESP32
*  - DHT11 GND Pin -> GND on ESP32
#include <DHT.h>  // Import the DHT library
// Define the GPIO pin where the DHT11 sensor is connected
#define DHTPIN 2       // DHT11 data pin is connected to GPIO2 on ESP32
// Define the type of DHT sensor being used (DHT11)
#define DHTTYPE DHT11  // DHT11 sensor type
// Create a DHT object to read temperature and humidity
DHT dht(DHTPIN, DHTTYPE);
  // Initialize serial communication for debugging at a baud rate of 115200
  Serial.println("DHT11 Sensor Test - Made by KinCony IoT: https://www.kincony.com");
  // Initialize the DHT sensor
  dht.begin();
  // Wait for 2 seconds between each reading to ensure stable data
  delay(2000);
  // Read humidity value from the DHT11 sensor
  float humidity = dht.readHumidity();
  // Read temperature value from the DHT11 sensor in Celsius
  float temperature = dht.readTemperature();
  // Check if there was an error reading the data
  if (isnan(humidity) || isnan(temperature)) {
    // Print error message if the sensor reading failed
    Serial.println("Failed to read from DHT11 sensor!");
    return;  // Exit loop iteration and try again after delay
  // Print the humidity value to the serial monitor
  Serial.print("Humidity: ");
  Serial.print(humidity);
  Serial.print("%");
  // Print the temperature value to the serial monitor
  Serial.print("  Temperature: ");
  Serial.print(temperature);
  Serial.println("°C");
arduino ino file download:
.zip   12-DHT11-temperature-humidity.zip (Size: 1.05 KB / Downloads: 449)
.zip   12-DHT11-temperature-humidity.ino.merged.zip (Size: 180.83 KB / Downloads: 472)
[arduino code examples for A32 Pro]-12 How to use DHT11 temperature humidity sensor - by admin - 09-20-2024, 05:12 AM
