[arduino code examples for AS]-01 internet radio
  Simple Internet Radio Demo
  esp32-i2s-simple-radio.ino
  Simple ESP32 I2S radio
  Uses MAX98357 I2S Amplifier Module
  Uses ESP32-audioI2S Library - https://github.com/schreibfaul1/ESP32-audioI2S
// Include required libraries
#include "Arduino.h"
#include "WiFi.h"
#include "Audio.h"
// Define I2S connections AS
#define I2S_DOUT  8
#define I2S_BCLK  7
#define I2S_LRC   6
// Create audio object
Audio audio;
// Wifi Credentials
String ssid =    "KinCony";
String password = "a12345678";
  // Start Serial Monitor
  // Setup WiFi in Station mode
  WiFi.disconnect();
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid.c_str(), password.c_str());
    delay(500);
    Serial.print(".");
  // WiFi Connected, print IP to serial monitor
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("");
  // Connect MAX98357 I2S Amplifier Module
  audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT);
  // Set thevolume (0-100)
  audio.setVolume(10);
  // Connect to an Internet radio station (select one as desired)
  audio.connecttohost("http://vis.media-ice.musicradio.com/CapitalMP3");
  //audio.connecttohost("mediaserv30.live-nect MAX98357 I2S Amplifier Module
  //audio.connecttohost("www.surfmusic.de/m3u/100-5-das-hitradio,4529.m3u");
  //audio.connecttohost("stream.1a-webradio.de/deutsch/mp3-128/vtuner-1a");
  //audio.connecttohost("www.antenne.de/webradio/antenne.m3u");
  //audio.connecttohost("0n-80s.radionetz.de:8000/0n-70s.mp3");
void loop()
  // Run audio player
  audio.loop();
// Audio status functions
void audio_info(const char *info) {
  Serial.print("info        "); Serial.println(info);
void audio_id3data(const char *info) { //id3 metadata
  Serial.print("id3data     "); Serial.println(info);
void audio_eof_mp3(const char *info) { //end of file
  Serial.print("eof_mp3     "); Serial.println(info);
void audio_showstation(const char *info) {
  Serial.print("station     "); Serial.println(info);
void audio_showstreaminfo(const char *info) {
  Serial.print("streaminfo  "); Serial.println(info);
void audio_showstreamtitle(const char *info) {
  Serial.print("streamtitle "); Serial.println(info);
void audio_bitrate(const char *info) {
  Serial.print("bitrate     "); Serial.println(info);
void audio_commercial(const char *info) { //duration in sec
  Serial.print("commercial  "); Serial.println(info);
void audio_icyurl(const char *info) { //homepage
  Serial.print("icyurl      "); Serial.println(info);
void audio_lasthost(const char *info) { //stream URL played
  Serial.print("lasthost    "); Serial.println(info);
void audio_eof_speech(const char *info) {
  Serial.print("eof_speech  "); Serial.println(info);
arduino ino file download:
.zip   internet-radio.zip (Size: 1.15 KB / Downloads: 878)
.zip   internet-radio.ino.merged.zip (Size: 849.07 KB / Downloads: 844)
just make sure replace wifi router's ssid and password by yourself.
[arduino code examples for AS]-01 internet radio - by admin - 10-22-2024, 12:39 AM
