H32B pro: No IP adress assigned to controller
(10-24-2024, 11:47 PM)admin Wrote: 1. your controller and  your router should in one same local network.
2. if webpage no data. re power on , after a little time open webpage, because it need time to get the data.
3. if really can't work well, you can try to download firmware again.
I tried the things you proposed.
1. Connect controller via ethernet cable to same acces point as laptop is cinncected to via wifi.
2. powered on and waited 2 minutes before connecting via webpage with ip http://192.168.1.200/ => Couldnt find
3: Installed firmware again via " flash_download_tool_3.9.2 " with USB ccable. I used the new firmware " H32B_Pro_V119_230820 " .
This was installed succesful.
After these steps still IP adress is 0.0.0.0.0 via the UDP scan tool, and also my router doesnt detect it .
Is there anything else I can try
RE: H32B pro: No IP adress assigned to controller - by kenny H - 10-25-2024, 01:49 PM
