KinCony ESP32-S3 Core Board released
(10-04-2024, 12:35 AM)admin Wrote: 1. if you want to use by home assistant, you can config by ESPHome.
2. if you want to write your own code, such as arduino IDE, you can write code and download to ESP32-S3 chip by USB-C cable.
i am using arduino ide for programming, however i having a problem when it is difficult to load the firmware.How to setup correct board ?
i am using arduino ide for programming, however i am having problem when it is difficult to load the firmware. How to setup so I can load the code using USB type c on the board
KinCony ESP32-S3 Core Board released - by admin - 05-10-2024, 11:12 AM
RE: KinCony ESP32-S3 Core Board released - by Julian - 12-04-2024, 01:45 AM
