12-09-2024, 10:20 PM
you should add "id" option, here is sample code for KC868-A8S, but the INPUT trigger OUTPUT as same way.
platform: ESP32
remote_receiver:
pin: 16
dump:
- rc_switch
tolerance: 50%
filter: 250us
idle: 2ms
buffer_size: 2kb
sda: 4
scl: 5
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
address: 0x24
address: 0x22
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
interlock: [relay6]
number: 4
mode: OUTPUT
interlock: [relay5]
number: 5
mode: OUTPUT
interlock: [relay8]
number: 6
mode: OUTPUT
interlock: [relay7]
number: 7
mode: OUTPUT
on_press:
then:
- switch.toggle: light1
pcf8574: pcf8574_hub_in_1
on_press:
then:
- switch.toggle: light2
on_press:
then:
- switch.toggle: light3
on_press:
then:
- switch.toggle: light4
on_press:
then:
- switch.toggle: relay5
number: 4
on_press:
then:
- switch.toggle: relay6
number: 5
on_press:
then:
- switch.toggle: relay7
number: 6
on_press:
then:
- switch.toggle: relay8
number: 7
- platform: remote_receiver
rc_switch_raw:
code: '001111010111001010111000'
protocol: 1
on_press:
then:
filters:
- delayed_off: 200ms
rc_switch_raw:
code: '001111010111001010111100'
protocol: 1
on_press:
then:
filters:
rc_switch_raw:
code: '001111010111001010110100'
protocol: 1
on_press:
then:
filters:
rc_switch_raw:
code: '001111010111001010111001'
protocol: 1
on_press:
then:
filters:
rc_switch_raw:
code: '001111010111001010110010'
protocol: 1
on_press:
then:
filters:
rc_switch_raw:
code: '001111010111001010110101'
protocol: 1
on_press:
then:
filters:
rc_switch_raw:
code: '001111010111001010110001'
protocol: 1
on_press:
then:
filters:
rc_switch_raw:
code: '001111010111001010110011'
protocol: 1
on_press:
then:
filters:
pin: 14
device_class: motion
on_release:
- script.execute: motion_timer
script:
- id: motion_timer
mode: restart
then:
- delay: 10s
- switch.turn_off: light1
- switch.turn_off: light2
- switch.turn_off: light3
- switch.turn_off: light4
