12-10-2024, 10:28 PM
Ok, maybe someone can help me on 2 issues
1. I added volume control and still sounds really low. no mater on if I set it to 100 or not
2. I tried to add continuous conversation and that is not working
friendly_name: SARAH
platformio_options:
board_build.flash_mode: dio
on_boot:
- light.turn_on:
red: 100%
green: 0.15
blue: 0.85
brightness: 50%
board: esp32-s3-devkitc-1
type: esp-idf
sdkconfig_options:
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
CONFIG_AUDIO_BOARD_CUSTOM: "y"
psram:
mode: octal # quad for N8R2 and octal for N16R8
speed: 80MHz
encryption:
key: "*********************"
on_client_connected:
then:
- delay: 50ms
- light.turn_on:
red: 100%
green: 0.15
blue: 0.85
brightness: 50%
- micro_wake_word.start:
on_client_disconnected:
then:
- voice_assistant.stop:
ota:
- platform: esphome
password: "****************"
wifi:
ssid: "********"
password: "************"
ap:
ssid: "Esp32-S3-Wake-Word"
password: "***********"
captive_portal:
button:
- platform: restart
# Updated Volume Control
number:
- platform: template
optimistic: true
min_value: 0
max_value: 100
step: 1
restore_value: true
initial_value: 80 # Higher default volume
mode: slider
on_value:
then:
- speaker.volume_set:
volume: !lambda "return (x / 100.0) * 8.0;"
optimistic: true
on_turn_on:
volume: 0%
- micro_wake_word.stop:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 60%
effect: fast pulse
- delay: 2s
- light.turn_off:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 30%
on_turn_off:
volume: 50%
- light.turn_on:
red: 0%
green: 100%
blue: 0%
brightness: 60%
effect: fast pulse
- delay: 2s
- light.turn_off:
light:
- platform: esp32_rmt_led_strip
rgb_order: RGB
pin: GPIO16
num_leds: 1
rmt_channel: 0
chipset: ws2812
name: "on board light"
effects:
- pulse:
- pulse:
transition_length: 0.5s
update_interval: 0.5s
min_brightness: 0%
max_brightness: 100%
# Audio and Voice Assistant Config
i2s_audio:
- id: i2s_in
i2s_lrclk_pin: GPIO3 #WS
i2s_bclk_pin: GPIO2 #SCK
- id: i2s_speaker
i2s_lrclk_pin: GPIO6 #LRC
i2s_bclk_pin: GPIO7 #BLCK
microphone:
- platform: i2s_audio
adc_type: external
i2s_din_pin: GPIO4 #SD pin on the INMP441
channel: left
pdm: false
i2s_audio_id: i2s_in
bits_per_sample: 32 bit
speaker:
i2s_audio_id: i2s_speaker
dac_type: external
i2s_dout_pin: GPIO8 # DIN Pin of the MAX98357A Audio Amplifier
channel: mono
micro_wake_word:
on_wake_word_detected:
- voice_assistant.start:
wake_word: !lambda return wake_word;
- light.turn_on:
red: 30%
green: 30%
blue: 70%
brightness: 60%
effect: fast pulse
models:
- model: hey_jarvis
voice_assistant:
microphone: va_mic
noise_suppression_level: 2.0
speaker: va_speaker
conversation_timeout: 10s # Time to wait for follow-up questions
on_tts_start:
then:
volume: !lambda "return (id(speaker_volume).state / 100.0) * 8.0;"
on_stt_end:
then:
- light.turn_on:
red: 100%
green: 0.15
blue: 0.85
brightness: 50%
effect: none
on_end:
then:
- light.turn_on:
red: 100%
green: 0.15
blue: 0.85
brightness: 50%
effect: none
- wait_until:
not:
voice_assistant.is_running:
