"KCS" v2.2.7 firmware BIN file download
Hi Admin,
I found out my answer to my own question no. 2.
Here is what I paste and it works:
  - name: 'sensor1-A16'
    unique_id: sensor1-A16
    state_topic: 'KC868_A16/AC1518FCC8P9/STATE'
    unit_of_measurement: 'C'
    value_template: '{{ value_json.sensor1.temperature }}'
For reference of others that bought KC868-A16, i will post my whole KC868-16 MQQT integration to home assistant below.
Now, I have another encountered problem, the temperature data on my Home Assistant is not updating, see image below:
I put a tested to input different numbers from 0.1 to 10, but still not updating, see image below for reference.
Sharing my complete code for KC868-A16 for this community/forum to help each other:
KC868-A16 integrate to home assistant by MQTT
default_config:
frontend:
  # Text to speech
tts:
  - platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
mqtt:
  - name: 'output-1-A16'
    unique_id: output-1-A16
    command_topic: 'KC868_A16/AC1518FCC8P9/SET'
    state_on: true
    state_off: false
  - name: 'output-2-A16'
    unique_id: output-2-A16
    state_on: true
    state_off: false
  - name: 'output-3-A16'
    unique_id: output-3-A16
    state_on: true
    state_off: false
  - name: 'output-4-A16'
    unique_id: output-4-A16
    state_on: true
    state_off: false
  - name: 'output-5-A16'
    unique_id: output-5-A16
    state_on: true
    state_off: false
  - name: 'output-6-A16'
    unique_id: output-6-A16
    state_on: true
    state_off: false
  - name: 'output-7-A16'
    unique_id: output-7-A16
    payload_on:  '{"output7":{"value":true}}'
    payload_off:  '{"output7":{"value":false}}'
    state_on: true
    state_off: false
  - name: 'output-8-A16'
    unique_id: output-8-A16
    payload_on:  '{"output8":{"value":true}}'
    payload_off:  '{"output8":{"value":false}}'
    state_on: true
    state_off: false
*****************i deleted the output 9-16 because I maxed the allowed text of 10000 characters*********
*************just copy and paste the output 8 and rename accordingly*****************
  - name: 'input-1-A16'
    unique_id: input-1-A16
    payload_on: true
    payload_off: false
  - name: 'input-2-A16'
    unique_id: input-2-A16
    payload_on: true
    payload_off: false
  - name: 'input-3-A16'
    unique_id: input-3-A16
    payload_on: true
    payload_off: false
  - name: 'input-4-A16'
    unique_id: input-4-A16
    payload_on: true
    payload_off: false
  - name: 'input-5-A16'
    unique_id: input-5-A16
    payload_on: true
    payload_off: false
  - name: 'input-6-A16'
    unique_id: input-6-A16
    payload_on: true
    payload_off: false
  - name: 'input-7-A16'
    unique_id: input-7-A16
    payload_on: true
    payload_off: false
  - name: 'input-8-A16'
    unique_id: input-8-A16
    payload_on: true
    payload_off: false
  - name: 'input-9-A16'
    unique_id: input-9-A16
    value_template: '{{ value_json.input9.value }}'
    payload_on: true
    payload_off: false
  - name: 'input-10-A16'
    unique_id: input-10-A16
    value_template: '{{ value_json.input10.value }}'
    payload_on: true
    payload_off: false
  - name: 'input-11-A16'
    unique_id: input-11-A16
    value_template: '{{ value_json.input11.value }}'
    payload_on: true
    payload_off: false
  - name: 'input-12-A16'
    unique_id: input-12-A16
    value_template: '{{ value_json.input12.value }}'
    payload_on: true
    payload_off: false
  - name: 'input-13-A16'
    unique_id: input-13-A16
    value_template: '{{ value_json.input13.value }}'
    payload_on: true
    payload_off: false
  - name: 'input-14-A16'
    unique_id: input-14-A16
    value_template: '{{ value_json.input14.value }}'
    payload_on: true
    payload_off: false
  - name: 'input-15-A16'
    unique_id: input-15-A16
    value_template: '{{ value_json.input15.value }}'
    payload_on: true
    payload_off: false
  - name: 'input-16-A16'
    unique_id: input-16-A16
    value_template: '{{ value_json.input16.value }}'
    payload_on: true
    payload_off: false
  - name: 'analog-1-A16'
    unique_id: analog-1-A16
    unit_of_measurement: 'v'
    value_template: '{{ value_json.adc1.value }}'
  - name: 'analog-2-A16'
    unique_id: analog-2-A16
    value_template: '{{ value_json.adc2.value }}'
  - name: 'analog-3-A16'
    unique_id: analog-3-A16
    value_template: '{{ value_json.adc3.value }}'
  - name: 'analog-4-A16'
    unique_id: analog-4-A16
    unit_of_measurement: 'meter'
    #value_template: '{{ value_json.adc4.value }}'
    value_template: '{{ (value_json.adc4.value  * 0.00122) |round(2) }}'
  - name: 'sensor2-A16'
    unique_id: sensor2-A16
    value_template: '{{ value_json.sensor2.temperature }}'
  - name: 'sensor3-A16'
    unique_id: sensor3-A16
    value_template: '{{ value_json.sensor3.temperature }}'
RE: "KCS" v2.2.7 firmware BIN file download - by mcroa - 12-13-2024, 03:15 AM
