Time control not working
#15
(01-05-2025, 11:23 PM)admin Wrote:
(01-02-2025, 10:38 PM)puterboy Wrote: I have the same problem!
UTC time offsets are incorrect and inconsistent
- On one board, UTC-N give UTC-(N+1). E.g., I am in Americas/New_York which is now on EST which is UTC-5 but when set to UTC-5, the time reads as UTC-4
- On another board, when set to UTC-5, it shows UTC-13
Also the display of time (under `index.html`) is non-standard. Specifically, it doesn't force 2 digits for the display of seconds, minutes (or hours).
For example: 4:07:05 reads as: 4:7:5 which I have never seen.
This should be a pretty simple bug in the code to correct as it just requires the correct arithmetic to add/subtract from UTC hours plus the correct formatting of the time printout.
Note I am using FW 2.2.10
which board model you are using? i send you a new firmware.
The same problem with KC868_AI. Instead of UTC+1 I need to setup UTC+8 to have correct time.
Time control not working - by kyxap - 03-20-2024, 06:21 AM
RE: Time control not working - by admin - 03-22-2024, 02:34 AM
RE: Time control not working - by kyxap - 03-22-2024, 07:10 AM
RE: Time control not working - by kyxap - 03-23-2024, 06:50 AM
RE: Time control not working - by kyxap - 03-23-2024, 02:22 AM
RE: Time control not working - by admin - 03-23-2024, 11:58 AM
RE: Time control not working - by pavksipo - 09-11-2024, 01:49 PM
RE: Time control not working - by mobob - 09-11-2024, 01:51 PM
RE: Time control not working - by pavksipo - 09-11-2024, 03:35 PM
RE: Time control not working - by puterboy - 01-02-2025, 10:38 PM
RE: Time control not working - by admin - 01-03-2025, 12:09 AM
RE: Time control not working - by admin - 01-05-2025, 11:23 PM
RE: Time control not working - by puterboy - 01-06-2025, 05:23 AM
RE: Time control not working - by xxpeta - 01-07-2025, 10:33 AM
RE: Time control not working - by admin - 01-06-2025, 10:54 AM
RE: Time control not working - by Mellie2025 - 01-08-2025, 03:58 PM
RE: Time control not working - by admin - 01-07-2025, 11:18 AM
RE: Time control not working - by admin - 01-08-2025, 11:16 PM
RE: Time control not working - by luzik1978 - 01-09-2025, 07:10 PM
RE: Time control not working - by admin - 01-09-2025, 11:16 PM
RE: Time control not working - by klakier2121 - 01-29-2025, 08:39 PM
RE: Time control not working - by admin - 02-03-2025, 05:26 AM
RE: Time control not working - by admin - 02-03-2025, 05:27 AM
RE: Time control not working - by klakier2121 - 02-03-2025, 08:50 PM
RE: Time control not working - by admin - 02-04-2025, 12:27 AM
