01-20-2025, 11:23 PM
this code have removed Tuya command for you.
yaml file download:
F16-HA-without-Tuya.txt (Size: 8.48 KB / Downloads: 428)
friendly_name: f16
board: esp32-s3-devkitc-1
type: arduino
encryption:
type: W5500
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
interrupt_pin: GPIO2
reset_pin: GPIO1
- id: bus_a
sda: 8
scl: 18
frequency: 400kHz
- id: 'pcf8574_hub_out_1' # for output channel 1-16
i2c_id: bus_a
address: 0x25
pcf8575: true
- id: 'pcf8574_hub_in_1' # for input channel 1-16
i2c_id: bus_a
address: 0x24
pcf8575: true
uart:
- id: uart_1 #RS485
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
tx_pin: 16
rx_pin: 17
- platform: uart
uart_id: uart_1
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_in_1
number: 4
number: 5
number: 6
number: 7
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
##pull-up resistance on PCB
number: 48
number: 47
number: 21
number: 15
## without resistance on PCB
number: 13
inverted: false
number: 14
inverted: false
number: 40
inverted: false
- platform: adc
pin: 5
name: "F16 A1 Voltage"
update_interval: 5s
attenuation: 11db
filters:
- lambda:
if (x >= 3.11) {
return x * 1.60256;
} else if (x <= 0.15) {
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 7
name: "F16 A2 Voltage"
update_interval: 5s
attenuation: 11db
filters:
# - multiply: 1.51515
- lambda:
if (x >= 3.11) {
return x * 1.60256;
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 6
name: "F16 A3 Current"
update_interval: 5s
unit_of_measurement: mA
attenuation: 11db
filters:
- multiply: 6.66666666
- platform: adc
pin: 4
name: "F16 A4 Current"
update_interval: 5s
attenuation: 11db
filters:
web_server:
port: 80
font:
- file: "gfonts://Roboto"
display:
- platform: ssd1306_i2c
i2c_id: bus_a
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.printf(0, 0, id(roboto), "KinCony F16");
