Can't Connect Over LAN
#13
(02-04-2025, 07:22 AM)Error7 Wrote: I've had to create a separate LAN from my main network because it is set up to 192.168.0.xxx. This is how I've configured my temporary LAN: I changed the IP address on my laptop to 192.168.1.14 then connected it to a spare router configured to  192.168.1.1. and connected the KC868-A16 to the router. When I run the flash_download_tool from my Windows GUI it results in the error as described previously.
The firmware update is done over USB, you shouldn't need to do anything with a LAN.
Leading to a followup question, are you trying to update it over a LAN? That would explain the error message you're seeing, the update is done over USB.
Can't Connect Over LAN - by Error7 - 01-29-2025, 01:47 PM
RE: Can't Connect Over LAN - by admin - 01-31-2025, 12:11 AM
RE: Can't Connect Over LAN - by Error7 - 01-31-2025, 10:16 AM
RE: Can't Connect Over LAN - by Error7 - 01-31-2025, 10:19 AM
RE: Can't Connect Over LAN - by admin - 01-31-2025, 11:45 PM
RE: Can't Connect Over LAN - by twostar - 02-01-2025, 10:46 AM
RE: Can't Connect Over LAN - by admin - 02-02-2025, 12:28 AM
RE: Can't Connect Over LAN - by Error7 - 02-03-2025, 01:55 PM
RE: Can't Connect Over LAN - by admin - 02-04-2025, 12:18 AM
RE: Can't Connect Over LAN - by Error7 - 02-04-2025, 07:22 AM
RE: Can't Connect Over LAN - by twostar - 02-04-2025, 03:25 AM
RE: Can't Connect Over LAN - by admin - 02-04-2025, 07:47 AM
RE: Can't Connect Over LAN - by twostar - 02-04-2025, 08:40 AM
RE: Can't Connect Over LAN - by Error7 - 02-04-2025, 10:48 AM
RE: Can't Connect Over LAN - by Error7 - 02-04-2025, 01:17 PM
RE: Can't Connect Over LAN - by admin - 02-05-2025, 12:06 AM
RE: Can't Connect Over LAN - by Error7 - 02-05-2025, 03:30 PM
RE: Can't Connect Over LAN - by twostar - 02-06-2025, 12:12 AM
RE: Can't Connect Over LAN - by Error7 - 02-06-2025, 12:55 PM
RE: Can't Connect Over LAN - by admin - 02-06-2025, 01:36 AM
RE: Can't Connect Over LAN - by admin - 02-07-2025, 01:07 AM
RE: Can't Connect Over LAN - by twostar - 02-07-2025, 05:13 AM
RE: Can't Connect Over LAN - by admin - 02-07-2025, 05:16 AM
RE: Can't Connect Over LAN - by twostar - 02-07-2025, 05:56 AM
RE: Can't Connect Over LAN - by admin - 02-07-2025, 06:26 AM
RE: Can't Connect Over LAN - by Error7 - 02-26-2025, 07:36 PM
RE: Can't Connect Over LAN - by admin - 02-26-2025, 10:22 PM
RE: Can't Connect Over LAN - by Error7 - 02-27-2025, 06:10 PM
RE: Can't Connect Over LAN - by admin - 02-27-2025, 11:54 PM
RE: Can't Connect Over LAN - by Error7 - 02-28-2025, 06:50 PM
RE: Can't Connect Over LAN - by admin - 03-01-2025, 01:23 AM
RE: Can't Connect Over LAN - by Error7 - 03-01-2025, 12:25 PM
RE: Can't Connect Over LAN - by admin - 03-02-2025, 12:58 AM
RE: Can't Connect Over LAN - by Error7 - 03-02-2025, 06:17 PM
RE: Can't Connect Over LAN - by admin - 03-02-2025, 10:56 PM
