02-10-2025, 12:43 AM
import smbus2
import time
# I2C device address
I2C_ADDR = 0x20
# MCP23017 register addresses
IODIRA = 0x00 # Port A direction register (1 = input, 0 = output)
IODIRB = 0x01 # Port B direction register
IPOLA = 0x02 # Port A polarity inversion register
IPOLB = 0x03 # Port B polarity inversion register
GPIOA = 0x12 # Port A data register
GPIOB = 0x13 # Port B data register
# Initialize I2C bus
bus = smbus2.SMBus(1) # Raspberry Pi default I2C-1
# Configure MCP23017 as input and enable polarity inversion
bus.write_byte_data(I2C_ADDR, IODIRA, 0xFF) # Set all Port A pins as input
bus.write_byte_data(I2C_ADDR, IODIRB, 0xFF) # Set all Port B pins as input
bus.write_byte_data(I2C_ADDR, IPOLA, 0xFF) # Invert polarity for Port A (1->0, 0->1)
bus.write_byte_data(I2C_ADDR, IPOLB, 0xFF) # Invert polarity for Port B
# Define pin names
pins = [
"Button_1", "Button_2", "Button_3", "Button_4",
"Button_5", "Button_6", "Button_7", "Button_8",
"Button_9", "Button_10", "Button_11", "Button_12",
"Button_13", "Button_14", "Button_15", "Button_16"
def read_inputs():
"""Read GPIOA and GPIOB from MCP23017 and parse button states"""
gpio_a = bus.read_byte_data(I2C_ADDR, GPIOA) # Read Port A
gpio_b = bus.read_byte_data(I2C_ADDR, GPIOB) # Read Port B
# Parse button states
states = [(gpio_a >> i) & 1 for i in range(8)] + [(gpio_b >> i) & 1 for i in range(8)]
return {pins[i]: states[i] for i in range(16)}
# Main loop: Read and display button states
try:
while True:
button_states = read_inputs()
print("Button States:", button_states)
time.sleep(0.5)
except KeyboardInterrupt:
print("\nProgram terminated")
bus.close()
