02-16-2025, 12:50 PM
I have a bug in the KC-868 A8.
Bug description:
- The board works fine for approximately 20 minutes, then It reboots.
Running EspHome Configuration:
Outcome:
- I have 16 lights in my apartment that are controlled with 2 KC-868 A8 boards. After approximately 20 minutes both boards reboot and all lights switch off, then I have to press the switches on again to have light.
Steps I tried:
- Review the EspHome config file. I don't see anything strange, Probably I am using a non recommended gpio that makes the trouble?
- Power supply review, I changed the power supply and connected to different sources but the problem persists. Is strange that both boards reboot at the same exact moment...
I appreciate some expert advice. Thanks
Bug description:
platform: ESP32
ota:
- platform: esphome
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
sda: 4
scl: 5
- id: 'out'
address: 0x24
- id: 'in'
address: 0x22
pcf8574: out
mode: OUTPUT
pcf8574: out
mode: OUTPUT
pcf8574: out
mode: OUTPUT
pcf8574: out
mode: OUTPUT
pcf8574: out
number: 4
mode: OUTPUT
pcf8574: out
number: 5
mode: OUTPUT
pcf8574: out
number: 6
mode: OUTPUT
pcf8574: out
number: 7
mode: OUTPUT
pcf8574: in
on_click:
min_length: 30ms
max_length: 500ms
then:
- switch.toggle: relay1
pcf8574: in
on_click:
min_length: 30ms
max_length: 500ms
then:
- switch.toggle: relay2
pcf8574: in
on_click:
min_length: 30ms
max_length: 500ms
then:
- switch.toggle: relay3
pcf8574: in
on_click:
min_length: 30ms
max_length: 500ms
then:
- switch.toggle: relay4
pcf8574: in
number: 4
on_click:
min_length: 30ms
max_length: 500ms
then:
- switch.toggle: relay5
pcf8574: in
number: 5
on_click:
min_length: 30ms
max_length: 500ms
then:
- switch.toggle: relay6
pcf8574: in
number: 6
on_click:
min_length: 30ms
max_length: 500ms
then:
- switch.toggle: relay7
pcf8574: in
number: 7
on_click:
min_length: 30ms
max_length: 500ms
then:
- switch.toggle: relay8
number: 32
number: 33
web_server:
version: 2
port: 80Outcome:
Steps I tried:
