02-26-2025, 11:14 PM
I have a problem that I can't solve. This is already my second board because I have a well-functioning A64 version, and now I'm trying to use the A128 version.
I'll start by saying that enabling MQTT (protocol->general->mqtt) is only possible for me on version v1.0.27. In firmware versions > v2 with IFTTT, it doesn't work—when I enable MQTT, the controller freezes, I can't access the web panel, and only a factory reset helps.
Only in version v1.0.27 does the controller not freeze after enabling MQTT. But here, I have another issue. When MQTT is enabled and I set any input to perform an action, after executing the action, the controller temporarily loses connection with the MQTT broker and then reconnects after a few seconds—I can't smoothly control the lights.
As I mentioned, I also have the A64 version, which runs on the same broker with firmware version 2.2.2, and everything works fine there. I have no more ideas on what could be wrong. I've checked the broker configuration, tried different settings, and nothing helps. I've also connected to external brokers, and the issue persists. I have flashed all your firmware versions onto the controller, and I can't get MQTT to work on any of them except for v1.0.27.
mqtt logs after input action (disconnectings)
![[Image: Bez-tytu-czxcxzcu.png]](https://i.postimg.cc/HkFwBp5K/Bez-tytu-czxcxzcu.png)
![[Image: veiosn.png]](https://i.postimg.cc/hvHmMsQm/veiosn.png)
![[Image: mqttt.png]](https://i.postimg.cc/NMFrcS1T/mqttt.png)
![[Image: status.png]](https://i.postimg.cc/gcwNyBfn/status.png)
