03-20-2025, 11:37 PM
8. What kind of Kincony LED driver can I use for dimm 220v LED bulbs or incandescent ones?
the SSR: https://shop.kincony.com/products/analog...-regulator
but we suggest use by DC LED strip, DC is stable than AC. here is DC driver:https://shop.kincony.com/products/0-10v-dimmable-led-drivers
9. What is the difference between "12V/24V 100W LED Dimmable Driver For KC868-D16" and "0 -10v Dimmable LED Drivers" when connecting it to KC868-D16+ ?
some LED strip use by 12V DC, some use by 24V DC. if your LED strip is long, use by long cable , 24V version is better.
10. (different topic) What type of cables should I prepare my house for different types of esp32 sensors ? (door, presence, humidity temperature etc) Will CAT6a cable be ok?
any cable can use, CAT5 is enough. our controller digital input ports circuit design use for long distance. CAT5 use by 300 meter no problem.
11. What type of cables should I prepare my house for the wall light switches? Would CAT6a cable be ok or should I use YSLY 7x0.75mm for control and use NYY-J 5x1.5mm for the load only?
I have already ordered KC868-A16v3 + KC868-E16v2. I was wondering if KC868-E16v2 manual buttons still work if the system is broken (like it is the case for F16 manual switch relays) ?
Yes, it's same.
Yes, it's same.
