#51
(04-01-2025, 11:59 PM)admin Wrote:
(02-27-2025, 11:52 PM)admin Wrote: you can try to test this code.
    type: arduino
external_components:
  - source:
      type: git
      url: https://github.com/hzkincony/esphome-zmpt101b
    refresh: 1min
  encryption:
    key: "D69bY/GXlmjYkovak6WIhgmbOH8vwyqvMxIHBriYoaY="
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  sda: 4
  scl: 5
cd74hc4067:
  - id: cd74hc4067_1
    pin_s0: 32
    pin_s1: 33
    pin_s2: 13
    pin_s3: 16
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "T: %.1f°C", id(temperature).state);
      it.printf(0, 20, id(roboto), "H: %.1f%%", id(humidity).state);
      it.printf(0, 40, id(roboto), "AC:%.1fV", id(voltage_1).state);
  - platform: zmpt101b
    name: "m16--AI zmpt 34"
    adc_pin: 34
    unit_of_measurement: V
    accuracy_decimals: 1
    state_class: "measurement"
    name: "m16--AI zmpt 36"
    adc_pin: 36
    name: "m16--AI zmpt 39"
    adc_pin: 39
  - platform: sht3xd
    temperature:
      name: "sht Temperature"
    humidity:
      name: "sht Humidity"
    address: 0x44
    update_interval: 5s
  - platform: adc
    pin: 35
    update_interval: never
    attenuation: 11db
  # - platform: adc
  #   name: "m16--AI-1"
  #   pin: 36
  #   id: adc36
  #   update_interval: 60s
  #   attenuation: 11db
  # - platform: adc
  #   pin: 34
  #   name: "m16--AI-2"
  #   id: adc34
  #   attenuation: 11db
  # - platform: adc
  #   pin: 39
  #   name: "m16--AI-3"
  #   id: adc39
  #   attenuation: 11db
  - platform: cd74hc4067
    sensor: adc35
    sensor: adc35
    sensor: adc35
    sensor: adc35
    number: 4
    sensor: adc35
    number: 5
    sensor: adc35
    number: 6
    sensor: adc35
    number: 7
    sensor: adc35
    number: 8
    sensor: adc35
    number: 9
    sensor: adc35
    number: 10
    sensor: adc35
    number: 11
    sensor: adc35
    number: 12
    sensor: adc35
    number: 13
    sensor: adc35
    number: 14
    sensor: adc35
    number: 15
    sensor: adc35
  - platform: ct_clamp
    sensor: ai1
    name: "Measured Current-1"
    update_interval: 5s
    filters:
      - calibrate_linear:
          # Measured value of 0 maps to 0A
          - 0.0034 -> 0
          # Known load: 4.0A
          # Value shown in logs: 0.1333A
          - 0.31749 -> 8.95608
  - platform: template
    lambda: return id(Measured_Current_1).state * id(voltage_1).state;
    device_class: power
    unit_of_measurement: 'W'
  - platform: total_daily_energy
    name: "Total Daily Energy1"
    power_id: power1
    filters:
        - multiply: 0.001
    unit_of_measurement: kWh
    accuracy_decimals: 3
    icon: mdi:clock-alert
    device_class: energy
    sensor: ai2
    name: "Measured Current-2"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai3
    name: "Measured Current-3"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai4
    name: "Measured Current-4"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai5
    name: "Measured Current-5"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai6
    name: "Measured Current-6"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai7
    name: "Measured Current-7"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai8
    name: "Measured Current-8"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai9
    name: "Measured Current-9"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai10
    name: "Measured Current-10"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai11
    name: "Measured Current-11"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai12
    name: "Measured Current-12"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai13
    name: "Measured Current-13"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai14
    name: "Measured Current-14"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai15
    name: "Measured Current-15"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai16
    name: "Measured Current-16"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
time:
  - platform: sntp
yaml file download:
just do as this yaml file, it have updated for newest esphome 2025.2.
just use this yaml file, you have tested two week ago.
KC868-M16v2 configure yaml for ESPhome - by admin - 07-18-2023, 01:33 PM
RE: KC868-M16v2 configure yaml for ESPhome - by admin - 04-06-2025, 12:24 PM
