04-10-2025, 12:44 PM
(04-10-2025, 01:25 AM)admin Wrote: v3.9.0 improvement:
1. fixed wifi can't disable in "AP" mode.
2. add support new controller F8 & A2v3 & A8v3 & B8M & TA
Just tested it and the WiFi-disable display bug is fixed, the web interface now correctly shows the WiFi status. However the OLED display still shows the incorrect status, so it shows the WiFi enabled even when it isn't.
The time zone bug is still present, it seems to use UTC no matter what time zone you set.
Also, setting a sensor type + GPIO bricks the board, requiring a reflash. For example under 'Sensor' set sensor #1 = DHT22, GPIO = 47 (the first option), "Save", and the board will be bricked, even a hardware reset won't work, you need to power cycle and reflash.
Finally, digital inputs seem to be dead, even if I directly connect the GND pin on the connector to, say DI9, the web interface ("Monitor") shows no change. This is a new v3 board that I haven't tried before so I'm not sure if this is faulty hardware or a software bug, it worked OK with the older v2 I had. I've tried directly bridging the pins on the board in case there's a problem with the connector and there's no change, it reports the DI input as not closed.
