A16v3 low voltage inputs
(04-09-2025, 09:20 AM)twostar Wrote: You need to remove the EOL resistors entirely, a dry-contact input can only have two states, either open-circuit (open) or short-circuit (closed).  The EOL resistors are putting a voltage across the input that shouldn't be there.
I think I'm having the same problem...Been working at this for days..
I bought the KC868-A16 because I have about 10 LD2410 sensors that I wanted to connect. The LD2410 has an OUT pin that outputs 3.x volts when someone is detected, and LOW when they are not.  The 1-8, 9-16 pins are all registering about 10v and don't react to the LD2410's 3.3v output.
Do I need to attach 16 relays to close the input pins?
thanks
A16v3 low voltage inputs - by jaydubnz - 04-09-2025, 05:58 AM
RE: A16v3 low voltage inputs - by admin - 04-09-2025, 08:09 AM
RE: A16v3 low voltage inputs - by jaydubnz - 04-09-2025, 08:22 AM
RE: A16v3 low voltage inputs - by twostar - 04-09-2025, 08:27 AM
RE: A16v3 low voltage inputs - by jaydubnz - 04-09-2025, 09:01 AM
RE: A16v3 low voltage inputs - by twostar - 04-09-2025, 09:20 AM
RE: A16v3 low voltage inputs - by jaydubnz - 04-11-2025, 08:40 AM
RE: A16v3 low voltage inputs - by Michaelmur - 04-18-2025, 04:01 AM
RE: A16v3 low voltage inputs - by twostar - 04-19-2025, 11:15 AM
