[arduino code examples for A2v3]-04 RS485 communication test
* RS485 Communication Test
* The TXD pin is defined as GPIO 18 and RXD pin is defined as GPIO 8.
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 15
#define RS485_TXD 7
  while (!Serial);
  // Send a test message
  rs485Serial.println("Hello from KinCony A2v3!");
  // Wait for a short period
  delay(1000);
    String receivedMessage = "";
      char c = rs485Serial.read();
      receivedMessage += c;
    // Print the received message
    Serial.print("Received: ");
  delay(2000);
arduino ino file download:
.zip   4-RS485-Test.zip (Size: 763 bytes / Downloads: 332)
.zip   4-RS485-Test.ino.merged.zip (Size: 184.35 KB / Downloads: 313)
[arduino code examples for A2v3]-04 RS485 communication test - by admin - 04-20-2025, 05:54 AM
