AS ESPHome yaml for home assistant
#23
because esphome is updated, just delete this line: rmt channel: 0
the new yaml file is:
  friendly_name: AS
  platformio_options:
    board_build.flash_mode: dio
  on_boot:
    - light.turn_on:
        blue: 100%
        brightness: 60%
        effect: fast pulse
  board: esp32-s3-devkitc-1
    type: esp-idf
    sdkconfig_options:
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
      CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
      CONFIG_AUDIO_BOARD_CUSTOM: "y"
psram:
  mode: octal  # quad for N8R2 and octal for N16R8
  speed: 80MHz
  encryption:
    key: "TFpb+pBAvQIS1MVwaA7EoJ2DkpWE+79UvVro7yMyGdU="
  on_client_connected:
        then:
          - delay: 50ms
          - light.turn_off: led_ww
          - micro_wake_word.start:
  on_client_disconnected:
        then:
          - voice_assistant.stop:
ota:
  - platform: esphome
    password: "1245211a05eef56614a2ef5a3f3e971c"
wifi:
  ssid: "KinCony"
  password: "a12345678"
  ap:
    ssid: "Esp32-S3-Wake-Word"
    password: "LJfUrdJk3svP"
captive_portal:
button:
  - platform: restart
  - platform: template
    optimistic: true
    on_turn_on:
      - micro_wake_word.stop:
      - light.turn_on:
          red: 100%
          green: 0%
          blue: 0%
          brightness: 60%
          effect: fast pulse
      - delay: 2s
      - light.turn_off:
      - light.turn_on:
          red: 100%
          green: 0%
          blue: 0%
          brightness: 30%
    on_turn_off:
      - light.turn_on:
          red: 0%
          green: 100%
          blue: 0%
          brightness: 60%
          effect: fast pulse
      - delay: 2s
      - light.turn_off:
light:
  - platform: esp32_rmt_led_strip
    rgb_order: RGB
    pin: GPIO16
    num_leds: 1
    chipset: ws2812
    name: "on board light"
    effects:
      - pulse:
      - pulse:
          transition_length: 0.5s
          update_interval: 0.5s
          min_brightness: 0%
          max_brightness: 100%
# Audio and Voice Assistant Config
i2s_audio:
  - id: i2s_in
    i2s_lrclk_pin: GPIO3  #WS
    i2s_bclk_pin: GPIO2 #SCK
  - id: i2s_speaker
    i2s_lrclk_pin: GPIO6  #LRC
    i2s_bclk_pin: GPIO7 #BLCK
microphone:
  - platform: i2s_audio
    adc_type: external
    i2s_din_pin: GPIO4 #SD pin on the INMP441
    channel: left
    pdm: false
    i2s_audio_id: i2s_in
    bits_per_sample: 32 bit
speaker:
    platform: i2s_audio
    i2s_audio_id: i2s_speaker
    dac_type: external
    i2s_dout_pin: GPIO8   #  DIN Pin of the MAX98357A Audio Amplifier
    channel: mono
micro_wake_word:
  on_wake_word_detected:
    # then:
    - voice_assistant.start:
        wake_word: !lambda return wake_word;
    - light.turn_on:
        red: 30%
        green: 30%
        blue: 70%
        brightness: 60%
        effect: fast pulse
  models:
    - model: github://esphome/micro-wake-word-models/models/v2/hey_jarvis.json
voice_assistant:
  microphone: va_mic
  noise_suppression_level: 2.0
  volume_multiplier: 4.0
  speaker: va_speaker
  on_stt_end:
       then:
  on_error:
  on_end:
        then:
          - wait_until:
              not:
                voice_assistant.is_running:
it can be compiled.
.txt   AS-HA-2.txt (Size: 3.98 KB / Downloads: 424)
AS ESPHome yaml for home assistant - by admin - 10-19-2024, 12:09 PM
RE: AS ESPHome yaml for home assistant - by admin - 11-09-2024, 12:00 PM
RE: AS ESPHome yaml for home assistant - by admin - 11-09-2024, 12:29 PM
RE: AS ESPHome yaml for home assistant - by admin - 11-12-2024, 10:17 PM
RE: AS ESPHome yaml for home assistant - by admin - 11-22-2024, 10:36 PM
RE: AS ESPHome yaml for home assistant - by admin - 11-28-2024, 11:00 PM
RE: AS ESPHome yaml for home assistant - by admin - 12-02-2024, 10:59 PM
RE: AS ESPHome yaml for home assistant - by admin - 12-05-2024, 11:21 PM
RE: AS ESPHome yaml for home assistant - by admin - 12-20-2024, 11:29 PM
RE: AS ESPHome yaml for home assistant - by admin - 12-28-2024, 01:23 AM
RE: AS ESPHome yaml for home assistant - by admin - 04-23-2025, 09:20 AM
RE: AS ESPHome yaml for home assistant - by admin - 07-24-2025, 12:28 AM
