06-09-2025, 08:52 AM
friendly_name: a128
type: arduino
- id: bus_a
sda: 5
scl: 16
frequency: 400kHz
- id: bus_b
sda: 15
scl: 4
frequency: 400kHz
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
# manual_ip:
# static_ip: 192.168.1.198
# gateway: 192.168.1.1
# subnet: 255.255.255.0
- id: 'pcf8574_hub_out_1' # for output channel 1-16
i2c_id: bus_a
address: 0x24
pcf8575: true
- id: 'pcf8574_hub_out_2' # for output channel 17-32
i2c_id: bus_a
address: 0x25
pcf8575: true
- id: 'pcf8574_hub_out_3' # for output channel 33-48
i2c_id: bus_a
address: 0x21
pcf8575: true
- id: 'pcf8574_hub_out_4' # for output channel 49-64
i2c_id: bus_a
address: 0x22
pcf8575: true
- id: 'pcf8574_hub_out_5' # for output channel 65-80
i2c_id: bus_a
address: 0x26
pcf8575: true
- id: 'pcf8574_hub_out_6' # for output channel 81-96
i2c_id: bus_a
address: 0x27
pcf8575: true
- id: 'pcf8574_hub_out_7' # for output channel 97-112
i2c_id: bus_a
address: 0x20
pcf8575: true
- id: 'pcf8574_hub_out_8' # for output channel 113-128
i2c_id: bus_a
address: 0x23
pcf8575: true
- id: 'pcf8574_hub_in_1' # for a128-input channel 1-16
i2c_id: bus_b
address: 0x24
pcf8575: true
- id: 'pcf8574_hub_in_2' # for a128-input channel 17-32
i2c_id: bus_b
address: 0x25
pcf8575: true
- id: 'pcf8574_hub_in_3' # for a128-input channel 33-48
i2c_id: bus_b
address: 0x21
pcf8575: true
- id: 'pcf8574_hub_in_4' # for a128-input channel 49-64
i2c_id: bus_b
address: 0x22
pcf8575: true
- id: 'pcf8574_hub_in_5' # for a128-input channel 65-80
i2c_id: bus_b
address: 0x26
pcf8575: true
- id: 'pcf8574_hub_in_6' # for a128-input channel 81-96
i2c_id: bus_b
address: 0x27
pcf8575: true
- id: 'pcf8574_hub_in_7' # for a128-input channel 97-112
i2c_id: bus_b
address: 0x20
pcf8575: true
- id: 'pcf8574_hub_in_8' # for a128-input channel 113-128
i2c_id: bus_b
address: 0x23
pcf8575: true
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_2
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_3
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_4
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_5
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_6
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_7
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_8
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
# Individual inputs
pcf8574: pcf8574_hub_in_1
on_press:
then:
- switch.toggle: light1
on_press:
then:
- switch.toggle: light2
on_press:
then:
- switch.toggle: light3
on_press:
then:
- switch.toggle: light4
number: 4
on_press:
then:
- switch.toggle: light5
number: 5
on_press:
then:
- switch.toggle: light6
number: 6
on_press:
then:
- switch.toggle: light7
number: 7
on_press:
then:
- switch.toggle: light8
number: 8
on_press:
then:
- switch.toggle: light9
number: 9
on_press:
then:
- switch.toggle: light10
number: 10
on_press:
then:
- switch.toggle: light11
number: 11
on_press:
then:
- switch.toggle: light12
number: 12
on_press:
then:
- switch.toggle: light13
number: 13
on_press:
then:
- switch.toggle: light14
number: 14
on_press:
then:
- switch.toggle: light15
number: 15
on_press:
then:
- switch.toggle: light16
pcf8574: pcf8574_hub_in_2
on_press:
then:
- switch.toggle: light17
on_press:
then:
- switch.toggle: light18
on_press:
then:
- switch.toggle: light19
on_press:
then:
- switch.toggle: light20
number: 4
on_press:
then:
- switch.toggle: light21
number: 5
on_press:
then:
- switch.toggle: light22
number: 6
on_press:
then:
- switch.toggle: light23
number: 7
on_press:
then:
- switch.toggle: light24
number: 8
on_press:
then:
- switch.toggle: light25
number: 9
on_press:
then:
- switch.toggle: light26
number: 10
on_press:
then:
- switch.toggle: light27
number: 11
on_press:
then:
- switch.toggle: light28
number: 12
on_press:
then:
- switch.toggle: light29
number: 13
on_press:
then:
- switch.toggle: light30
number: 14
on_press:
then:
- switch.toggle: light31
number: 15
on_press:
then:
- switch.toggle: light32
pcf8574: pcf8574_hub_in_3
on_press:
then:
- switch.toggle: light33
on_press:
then:
- switch.toggle: light34
on_press:
then:
- switch.toggle: light35
on_press:
then:
- switch.toggle: light36
number: 4
on_press:
then:
- switch.toggle: light37
number: 5
on_press:
then:
- switch.toggle: light38
number: 6
on_press:
then:
- switch.toggle: light39
number: 7
on_press:
then:
- switch.toggle: light40
number: 8
on_press:
then:
- switch.toggle: light41
number: 9
on_press:
then:
- switch.toggle: light42
number: 10
on_press:
then:
- switch.toggle: light43
number: 11
on_press:
then:
- switch.toggle: light44
number: 12
on_press:
then:
- switch.toggle: light45
number: 13
on_press:
then:
- switch.toggle: light46
number: 14
on_press:
then:
- switch.toggle: light47
number: 15
on_press:
then:
- switch.toggle: light48
pcf8574: pcf8574_hub_in_4
on_press:
then:
- switch.toggle: light49
on_press:
then:
- switch.toggle: light50
on_press:
then:
- switch.toggle: light51
on_press:
then:
- switch.toggle: light52
number: 4
on_press:
then:
- switch.toggle: light53
number: 5
on_press:
then:
- switch.toggle: light54
number: 6
on_press:
then:
- switch.toggle: light55
number: 7
on_press:
then:
- switch.toggle: light56
number: 8
on_press:
then:
- switch.toggle: light57
number: 9
on_press:
then:
- switch.toggle: light58
number: 10
on_press:
then:
- switch.toggle: light59
number: 11
on_press:
then:
- switch.toggle: light60
number: 12
on_press:
then:
- switch.toggle: light61
number: 13
on_press:
then:
- switch.toggle: light62
number: 14
on_press:
then:
- switch.toggle: light63
number: 15
on_press:
then:
- switch.toggle: light64
pcf8574: pcf8574_hub_in_5
on_press:
then:
- switch.toggle: light65
on_press:
then:
- switch.toggle: light66
on_press:
then:
- switch.toggle: light67
on_press:
then:
- switch.toggle: light68
number: 4
on_press:
then:
- switch.toggle: light69
number: 5
on_press:
then:
- switch.toggle: light70
number: 6
on_press:
then:
- switch.toggle: light71
number: 7
on_press:
then:
- switch.toggle: light72
number: 8
on_press:
then:
- switch.toggle: light73
number: 9
on_press:
then:
- switch.toggle: light74
number: 10
on_press:
then:
- switch.toggle: light75
number: 11
on_press:
then:
- switch.toggle: light76
number: 12
on_press:
then:
- switch.toggle: light77
number: 13
on_press:
then:
- switch.toggle: light78
number: 14
on_press:
then:
- switch.toggle: light79
number: 15
on_press:
then:
- switch.toggle: light80
pcf8574: pcf8574_hub_in_6
on_press:
then:
- switch.toggle: light81
on_press:
then:
- switch.toggle: light82
on_press:
then:
- switch.toggle: light83
on_press:
then:
- switch.toggle: light84
number: 4
on_press:
then:
- switch.toggle: light85
number: 5
on_press:
then:
- switch.toggle: light86
number: 6
on_press:
then:
- switch.toggle: light87
number: 7
on_press:
then:
- switch.toggle: light88
number: 8
on_press:
then:
- switch.toggle: light89
number: 9
on_press:
then:
- switch.toggle: light90
number: 10
on_press:
then:
- switch.toggle: light91
number: 11
on_press:
then:
- switch.toggle: light92
number: 12
on_press:
then:
- switch.toggle: light93
number: 13
on_press:
then:
- switch.toggle: light94
number: 14
on_press:
then:
- switch.toggle: light95
number: 15
on_press:
then:
- switch.toggle: light96
pcf8574: pcf8574_hub_in_7
on_press:
then:
- switch.toggle: light97
on_press:
then:
- switch.toggle: light98
on_press:
then:
- switch.toggle: light99
on_press:
then:
- switch.toggle: light100
number: 4
on_press:
then:
- switch.toggle: light101
number: 5
on_press:
then:
- switch.toggle: light102
number: 6
on_press:
then:
- switch.toggle: light103
number: 7
on_press:
then:
- switch.toggle: light104
number: 8
on_press:
then:
- switch.toggle: light105
number: 9
on_press:
then:
- switch.toggle: light106
number: 10
on_press:
then:
- switch.toggle: light107
number: 11
on_press:
then:
- switch.toggle: light108
number: 12
on_press:
then:
- switch.toggle: light109
number: 13
on_press:
then:
- switch.toggle: light110
number: 14
on_press:
then:
- switch.toggle: light111
number: 15
on_press:
then:
- switch.toggle: light112
pcf8574: pcf8574_hub_in_8
on_press:
then:
- switch.toggle: light113
on_press:
then:
- switch.toggle: light114
on_press:
then:
- switch.toggle: light115
on_press:
then:
- switch.toggle: light116
number: 4
on_press:
then:
- switch.toggle: light117
number: 5
on_press:
then:
- switch.toggle: light118
number: 6
on_press:
then:
- switch.toggle: light119
number: 7
on_press:
then:
- switch.toggle: light120
number: 8
on_press:
then:
- switch.toggle: light121
number: 9
on_press:
then:
- switch.toggle: light122
number: 10
on_press:
then:
- switch.toggle: light123
number: 11
on_press:
then:
- switch.toggle: light124
number: 12
on_press:
then:
- switch.toggle: light125
number: 13
on_press:
then:
- switch.toggle: light126
number: 14
on_press:
then:
- switch.toggle: light127
number: 15
on_press:
then:
- switch.toggle: light128
web_server:
port: 80
KC868-A128-HA-input-toggle-output.txt (Size: 50.21 KB / Downloads: 317)
firmware BIN file download (download at 0x0 address , directly to use):
a128-input-toggle-output.zip (Size: 418.19 KB / Downloads: 528)
after download firmware, ethernet will work as DHCP mode. find the IP address from your router, then use IP address login by web browser.
