[arduino code examples for B8M]-01 Turn ON/OFF OUTPUT
* This program controls a 16-channel relay board via a PCF8575 I/O expander.
* It sequentially turns on each relay and then turns them off in a loop.
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* Delay Time:
* - 200 milliseconds between switching relays
#include <Wire.h>        // Include the Wire library for I2C communication
#include <PCF8575.h>     // Include the PCF8575 library to control the I/O expander
#define SDA 8           // Define the SDA pin
#define SCL 18          // Define the SCL pin
#define DELAY_TIME 200   // Define the delay time in milliseconds
// Set I2C address of the PCF8575 module
#define I2C_ADDRESS 0x22 // I2C address of the PCF8575 module
PCF8575 pcf8575_R1(I2C_ADDRESS); // Create a PCF8575 object with the specified I2C address
  Wire.begin(SDA, SCL); // SDA on GPIO 8, SCL on GPIO 18 (according to your board's configuration)
  // Initialize serial communication for debugging (optional)
  Serial.println("PCF8575 Relay Control: Starting...");
  // Initialize the PCF8575 module
  pcf8575_R1.begin();
  // Turn off all relays initially (set all pins HIGH)
  for (int i = 0; i < 8; i++) {
    pcf8575_R1.write(i, HIGH); // Set all relays to OFF (assuming HIGH means OFF for relays)
  // Sequentially turn on each relay
    pcf8575_R1.write(i, LOW);   // Turn on the relay at pin i (LOW means ON for the relay)
    delay(DELAY_TIME);          // Wait for DELAY_TIME milliseconds
  // Sequentially turn off each relay
    pcf8575_R1.write(i, HIGH);  // Turn off the relay at pin i (HIGH means OFF for the relay)
arduino ino file download:
.zip   1-output.zip (Size: 925 bytes / Downloads: 396)
.zip   1-output.ino.merged.zip (Size: 189.23 KB / Downloads: 374)
[arduino code examples for B8M]-01 Turn ON/OFF OUTPUT - by admin - 06-21-2025, 03:49 AM
