[arduino code examples for B8M]-04 RS485 communication test
* RS485 Communication Test
* The TXD pin is defined as GPIO 18 and RXD pin is defined as GPIO 8.
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 38
#define RS485_TXD 39
  while (!Serial);
  // Send a test message
  rs485Serial.println("Hello from KinCony B8M!");
  // Wait for a short period
  delay(1000);
    String receivedMessage = "";
      char c = rs485Serial.read();
      receivedMessage += c;
    // Print the received message
    Serial.print("Received: ");
  delay(2000);
arduino ino file download:
.zip   4-RS485-Test.zip (Size: 763 bytes / Downloads: 337)
.zip   4-RS485-Test.ino.merged.zip (Size: 184.35 KB / Downloads: 360)
[arduino code examples for B8M]-04 RS485 communication test - by admin - 06-21-2025, 03:54 AM
