#70
Hi, I have just bought the KC868-M16-V2.1 and I'm having the same issue display is working with temp and humidity reading but I have no Ethernet working.
I have tried the m16v2.factory.zip and the yaml example supplied in this thread with no luck.
If i use the yaml example for the KC868-M16 the Ethernet works fine but I have no display, temp or humidity
I had the same issue with no Ethernet but I was able to resolve it by using esptool to erase and flash the m16v2.factory.bin
esptool -p /dev/ttyUSB0 erase_flash
esptool --chip esp32 -p /dev/ttyUSB0 -b 115200 write_flash 0x0 m16v2.factory.bin
Now Ethenet works and so does the display.
KC868-M16v2 configure yaml for ESPhome - by admin - 07-18-2023, 01:33 PM
RE: KC868-M16v2 configure yaml for ESPhome - by The_Muffin_Man - 06-21-2025, 11:02 AM
