06-23-2025, 05:32 AM
friendly_name: t128m
board: esp32-s3-devkitc-1
type: esp-idf
type: W5500
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
interrupt_pin: GPIO2
reset_pin: GPIO1
- id: bus_a
sda: 48
scl: 47
frequency: 400kHz
- id: bus_b
sda: 12
scl: 11
frequency: 400kHz
- id: 'pcf8574_hub_out_1' # for output channel 1-16
i2c_id: bus_a
address: 0x27
pcf8575: true
- id: 'pcf8574_hub_out_2' # for output channel 17-32
i2c_id: bus_a
address: 0x26
pcf8575: true
- id: 'pcf8574_hub_out_3' # for output channel 33-48
i2c_id: bus_a
address: 0x23
pcf8575: true
- id: 'pcf8574_hub_out_4' # for output channel 49-64
i2c_id: bus_a
address: 0x22
pcf8575: true
- id: 'pcf8574_hub_out_5' # for output channel 65-80
i2c_id: bus_a
address: 0x25
pcf8575: true
- id: 'pcf8574_hub_out_6' # for output channel 81-96
i2c_id: bus_a
address: 0x24
pcf8575: true
- id: 'pcf8574_hub_out_7' # for output channel 97-112
i2c_id: bus_a
address: 0x21
pcf8575: true
- id: 'pcf8574_hub_out_8' # for output channel 113-128
i2c_id: bus_a
address: 0x20
pcf8575: true
- id: 'pcf8574_hub_in_1' # for input channel 1-16
i2c_id: bus_b
address: 0x27
pcf8575: true
- id: 'pcf8574_hub_in_2' # for input channel 17-32
i2c_id: bus_b
address: 0x26
pcf8575: true
- id: 'pcf8574_hub_in_3' # for input channel 33-48
i2c_id: bus_b
address: 0x23
pcf8575: true
- id: 'pcf8574_hub_in_4' # for input channel 49-64
i2c_id: bus_b
address: 0x22
pcf8575: true
- id: 'pcf8574_hub_in_5' # for input channel 65-80
i2c_id: bus_b
address: 0x25
pcf8575: true
- id: 'pcf8574_hub_in_6' # for input channel 81-96
i2c_id: bus_b
address: 0x24
pcf8575: true
- id: 'pcf8574_hub_in_7' # for input channel 97-112
i2c_id: bus_b
address: 0x21
pcf8575: true
- id: 'pcf8574_hub_in_8' # for input channel 113-128
i2c_id: bus_b
address: 0x20
pcf8575: true
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_2
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_3
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_4
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_5
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_6
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_7
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_8
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_in_1
number: 4
number: 5
number: 6
number: 7
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_in_2
number: 4
number: 5
number: 6
number: 7
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_in_3
number: 4
number: 5
number: 6
number: 7
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_in_4
number: 4
number: 5
number: 6
number: 7
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_in_5
number: 4
number: 5
number: 6
number: 7
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_in_6
number: 4
number: 5
number: 6
number: 7
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_in_7
number: 4
number: 5
number: 6
number: 7
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_in_8
number: 4
number: 5
number: 6
number: 7
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
## pull-up resistance on PCB
number: 15
number: 16
inverted: false
number: 17
inverted: false
number: 18
inverted: false
## without pull-up resistance on PCB
inverted: false
number: 8
inverted: false
number: 9
inverted: false
number: 10
inverted: false
- platform: adc
pin: 7
name: "t128m A1 Voltage"
update_interval: 5s
attenuation: 11db
filters:
- lambda:
if (x >= 3.11) {
return x * 1.60256;
} else if (x <= 0.15) {
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 6
name: "t128m A2 Voltage"
update_interval: 5s
attenuation: 11db
filters:
# - multiply: 1.51515
- lambda:
if (x >= 3.11) {
return x * 1.60256;
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 5
name: "t128m A3 Current"
update_interval: 5s
unit_of_measurement: mA
attenuation: 11db
filters:
- multiply: 6.66666666
- platform: adc
pin: 4
name: "t128m A4 Current"
update_interval: 5s
attenuation: 11db
filters:
web_server:
port: 80
T128M-HA.txt (Size: 45.57 KB / Downloads: 132)
