Home Assistant mqtt don't works - inputs/outputs unavailable
Dear Kincony
I have a new  KC868_A8
I bought to use it with Home Assistant input/output
I set mqtt on the KC868_A8 as your guide and it works fine. Connection is done.
I have a problem on home assistant - it can find all the inputs/outputs but the are always unavailable. Can't work
Where is the problem?
I see the IP of the board is not set on the configuration file. Is it right?
the board is: KC868-A8-V1.7
home assistant is updated to last version
enclosed you can find the configuration.yaml file
how can I fix?
thank you in adavance, best regards from Italy!
.txt   configuration.yaml.txt (Size: 5.67 KB / Downloads: 218)
Home Assistant mqtt don't works - inputs/outputs unavailable - by AlenDinDon - 07-19-2025, 04:16 PM
