B24M ESPHome yaml for home assistant without tuya
  friendly_name: b24
  board: esp32-s3-devkitc-1
    type: arduino
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  interrupt_pin: GPIO43
  reset_pin: GPIO44
uart:
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 39
    rx_pin: 38
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
  - id: 'pcf8574_hub_in_1'  # for input channel 1-16
    i2c_id: bus_a
    address: 0x22
    pcf8575: true
  - id: 'pcf8574_hub_in_out_1'  # for digital input channel 17-24 & ouptut 1-8
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_out_1'  # for output channel 9-24
    i2c_id: bus_a
    address: 0x24
    pcf8575: true
      pcf8574: pcf8574_hub_in_1
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      number: 4
      number: 5
      number: 6
      number: 7
      pcf8574: pcf8574_hub_in_out_1
      number: 4
      number: 5
      number: 6
      number: 7
##pull-up resistance on PCB
      number: 48
      number: 47
      number: 40
      number: 7
## without resistance on PCB
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 21
      inverted:  false
      inverted:  false
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
  - platform: uart
    uart_id: uart_1
ads1115:
  - address: 0x48
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A1_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A2_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A3_GND'
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony B24");
download yaml file:
.txt   B24-HA-without Tuya.txt (Size: 10.92 KB / Downloads: 119)
B24M ESPHome yaml for home assistant without tuya - by admin - 07-31-2025, 06:52 AM
