Connect RS485 KC868-HAv2 to Server Mini
Help: Connect RS485 I/O modules to the Raspberry Pi 4 Relay Board (Server Mini) + Home Assistant OS
Hardware
Goal
  1. Daisy-chain several KinCony RS485 I/O modules to the Server Mini’s onboard RS485.
  2. Control/monitor them from Home Assistant OS (HA Modbus if possible).
  3. Best-practice for addressing many modules (bulk provisioning) without connecting a laptop each time.
What I’ve found / tried so far
  • The board exposes RS485 via the Pi’s UART (I see pins marked GPIO14 = TX, GPIO15 = RX on documentation/pins).
  • On Home Assistant OS, I cannot just edit /boot/config.txt like on Raspberry Pi OS, so I’m not sure about the correct way to enable the UART for the onboard RS485 under HA OS.
  • I tried using generic HA Modbus config but I’m not 100% sure about the device path (e.g. /dev/ttyAMA0, /dev/ttyS0, or /dev/serial/by-id/...) and serial parameters (baud, parity, stop bits) for KinCony’s RS485 port on this board.
Questions
  1. Wiring
    • Do I need a 120 Ω termination resistor at the last device? Are there built-in bias resistors on the Server Mini’s RS485 transceiver, or should I add my own?
    • Any max bus length / topology recommendations? (I’ll use daisy chain, not star.)
  2. Protocol & parameters
    • Do those RS485 I/O modules speak Modbus RTU out of the box? If yes, what are the default serial parameters (baud, parity, stopbits) and the register map (coils/inputs/holding)?
    • If it’s not Modbus RTU by default, is there a Modbus firmware or config mode I should use?
  3. Addressing multiple modules
    • How do I set unique addresses for each module? DIP switches? Command?
    • For bulk installs, is there a recommended workflow to assign addresses without hooking up each module to a PC? (Auto-addressing, scan/assign tool, etc.)
  4. Home Assistant OS specifics
    • On this KinCony board with HA OS, what is the correct serial device path for the onboard RS485 (e.g., /dev/ttyAMA0)?
    • What is the recommended way to enable UART on HA OS for this board (since /boot/config.txt is read-only under HA OS)? Any KinCony-specific steps or an add-on?
    • A minimal, known-good Home Assistant modbus: YAML example for one RS485 I/O module would be super helpful.
  5. Examples
    • Could you share example register addresses (coils/inputs) for:
      • Reading digital inputs from a KinCony RS485 I/O module
      • Controlling a relay output (if the chosen module has relays)
    • Any sample configs for more than one module on the same bus?
Connect RS485 KC868-HAv2 to Server Mini - by Mijoo - 08-13-2025, 02:05 PM
