KC 868-A16 RS485
Exclamation
I am trying to connect a pressure sensor to my KC868-A16 board using RS485 communication. The sensor works via Modbus RTU, and I want the KC868-A16 to act as the master.
Here are the issues I am facing:
  1. On the web configuration page of KC868, I can see General Protocol and Custom Protocol, but I am not sure which one I should use for the pressure sensor, since it is not listed in the default devices.
  2. I have tested the RS485 line with a USB-RS485 adapter and Modbus Poll, and I can see the sensor replying with values (e.g. 500, 0, 500, …). So the sensor is working correctly.
  3. When I try to scan for slave IDs from Python via the KC RS485, I only get timeout errors. TX is active, but RX never receives data.
  4. I have already checked the wiring (A↔A, B↔B, and GND connected), baudrate, parity, stopbits, and slave ID, but still no communication between KC and the pressure sensor.
So my questions are:
  • How should I configure KC868 in the web interface to read registers from the pressure sensor?
  • Do I need to use General Protocol or Custom Protocol?
  • Is there any example of how to set the registers mapping for an external Modbus RTU sensor?
Thanks in advance for your help!
KC 868-A16 RS485 - by daudrimu - 09-03-2025, 08:34 AM
RE: KC 868-A16 RS485 - by admin - 09-03-2025, 10:32 AM
