09-04-2025, 12:52 PM
Ok, this is my current code with very small changes and update to use ESPHome 2025.8.3!
I have split the code in two post because I receive the error for the message too long:
friendly_name: KC868-A32
type: esp-idf
version: recommended
# level: VERBOSE
ota:
- platform: esphome
password: "ota_password"
safe_mode:
reboot_timeout: 10min # Longer Timeout
num_attempts: 3 # Multiple attempts
# ________________________________________________________________________________
# Network Configuration
# --- WiFi
#wifi:
# ssid: !secret wifi_ssid
# password: !secret wifi_password
# ap:
# ssid: "Kc868-A32 Fallback Hotspot"
# password: "ap_password"
#captive_portal:
# --- Ethernet
# Ethernet configuration entry (It's possible to use only WIFI or only Ethernet, not both)
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk:
pin: GPIO17
mode: CLK_OUT
phy_addr: 0
manual_ip: # Recommended for router compatibility
static_ip: 192.168.1.183
gateway: 192.168.1.254
subnet: 255.255.255.0
dns1: 8.8.8.8 # Primary DNS
dns2: 8.8.4.4 # Secondary DNS
# Alternative debug and OTA web server
web_server:
port: 80
version: 2
include_internal: true
# Syncronize the time with the Home Assistant
time:
- platform: homeassistant
timezone: Europe/Rome
- id: bus_a
sda: 15
scl: 13
frequency: 100kHz # Lower frequency for stability
- id: bus_b
sda: 4
scl: 5
i2c_id: bus_a
address: 0x24
i2c_id: bus_a
address: 0x25
- id: 'pcf8574_hub_out_3' # for output channel 17-24
i2c_id: bus_a
address: 0x21
- id: 'pcf8574_hub_out_4' # for output channel 25-32
i2c_id: bus_a
address: 0x22
i2c_id: bus_b
address: 0x24
i2c_id: bus_b
address: 0x25
- id: 'pcf8574_hub_in_3' # for input channel 17-24
i2c_id: bus_b
address: 0x21
- id: 'pcf8574_hub_in_4' # for input channel 25-32
i2c_id: bus_b
address: 0x22
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_out_2
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_out_3
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_out_4
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
# Continued in the next post
