T16M Output after reset
Hi Kincony
Just received my 2.nd T16M, and upgraded both the new and the "Old" T16M to newest rel 3.15.0
I now see the original problem on both T16M controllers, and I'm able to reproduce the problem
Simple IFTTT settings: IN1 toggle OUT1 and IN2 toggle OUT2
If I, under monitor window, set the OUT1 & OUT2 to high, and toggle contacts physically connected to IN1 & IN2 a few times, and leaves OUT1 & OUT2 to high. Performs a reset or reboot of the controller, the high state is saved, and correctly restored after a reset on OUT1 & OUT2
If I, by toggling the input, set OUT1 & OUT2 to high, and in the GUI, under monitor window, set OUT1 & OUT2 to low. Toggle the 2 inputs, by the connected switches, to high, and then reboot or reset the controller both OUT1 & OUT2 comes up low
It looks like only the state from the monitor window is saved correctly, but not the state after toggling the outputs high if it is set low in the monitor window as written just above
I can reproduce on both controllers !!
Tried to reset, power toggle etc, but I'm able to reproduce every time I try now
Br Steen
T16M Output after reset - by Steen - 09-12-2025, 01:15 PM
RE: T16M Output after reset - by admin - 09-12-2025, 11:50 PM
RE: T16M Output after reset - by Steen - 09-14-2025, 07:51 AM
RE: T16M Output after reset - by admin - 09-15-2025, 02:44 AM
RE: T16M Output after reset - by Steen - 09-15-2025, 07:25 AM
RE: T16M Output after reset - by admin - 09-16-2025, 01:35 AM
RE: T16M Output after reset - by Steen - 11-28-2025, 01:55 PM
RE: T16M Output after reset - by admin - 11-29-2025, 12:48 AM
RE: T16M Output after reset - by Steen - 11-29-2025, 05:09 PM
