01-04-2026, 06:26 AM
(01-04-2026, 12:23 AM)admin Wrote: 1. because you have not connect with RED cable in photo.
2. if you want digital input work with digital output, you need set by IFTTT, you can check KCS v2 online guide firstly. here is online guide:
https://www.kincony.com/esp32-kcsv2-firmware.html
1. I've set up wireless connection in the wifi section. The board is connected to the wifi network and I connect to the admin interface typing in the web browser the board's IP address.
2. I've checked the online guide. That is how I flashed the firmware and set up the board. Then I connected to the board's wifi network on my phone and set up STA wifi connection. After the board connected to the wifi network I connected to it using my computer. This is how I access the boards admin interface.
What do you mean by:
Quote:if you want digital input work with digital output, you need set by IFTTTI don't want to set up automatizations yet.
Right now I just clicked on the button ALL ON / ALL OFF and I expected the board will turn on / off all the outputs. Nothing happens. No indicator lights come on nor there is continuity at the outputs. I've tried shorting the inputs and nothing happens either.
Thanks!
