Connect um330 and kc828 a16
#27
(01-07-2026, 07:17 AM)admin Wrote: COLB integrate to home assistant by mqtt, here is guide: https://www.kincony.com/mqtt-input-modul...stant.html
COLB analog input port for 0-5v
Previously, I was told that it’s possible to convert a 4–20 mA signal for use with the COLB. Could you please explain how to do that? Also, is MQTT integration with Home Assistant possible over Wi-Fi, or is it only supported via Ethernet?
(10-16-2025, 10:43 AM)admin Wrote: KC868-COLB is 16 channel 0-5v analog input ports, you can convert to 4-20mA, so that can integrate to home assistant by MQTT.
Connect um330 and kc828 a16 - by gtd0916 - 06-25-2025, 08:07 AM
RE: Connect um330 and kc828 a16 - by admin - 06-25-2025, 11:42 AM
RE: Connect um330 and kc828 a16 - by gtd0916 - 06-26-2025, 12:30 AM
RE: Connect um330 and kc828 a16 - by admin - 06-26-2025, 06:16 AM
RE: Connect um330 and kc828 a16 - by gtd0916 - 06-26-2025, 07:37 AM
RE: Connect um330 and kc828 a16 - by admin - 06-26-2025, 07:43 AM
RE: Connect um330 and kc828 a16 - by gtd0916 - 06-26-2025, 07:50 AM
RE: Connect um330 and kc828 a16 - by admin - 06-26-2025, 07:51 AM
RE: Connect um330 and kc828 a16 - by gtd0916 - 06-26-2025, 08:23 AM
RE: Connect um330 and kc828 a16 - by admin - 06-26-2025, 08:52 AM
RE: Connect um330 and kc828 a16 - by gtd0916 - 07-03-2025, 07:07 AM
RE: Connect um330 and kc828 a16 - by admin - 07-03-2025, 07:54 AM
RE: Connect um330 and kc828 a16 - by gtd0916 - 07-03-2025, 01:40 PM
RE: Connect um330 and kc828 a16 - by admin - 07-04-2025, 12:39 AM
RE: Connect um330 and kc828 a16 - by gtd0916 - 07-04-2025, 01:21 AM
RE: Connect um330 and kc828 a16 - by admin - 07-04-2025, 03:45 AM
RE: Connect um330 and kc828 a16 - by gtd0916 - 07-04-2025, 06:09 AM
RE: Connect um330 and kc828 a16 - by admin - 07-04-2025, 06:13 AM
RE: Connect um330 and kc828 a16 - by gtd0916 - 10-16-2025, 05:36 AM
RE: Connect um330 and kc828 a16 - by admin - 10-16-2025, 06:05 AM
RE: Connect um330 and kc828 a16 - by gtd0916 - 10-16-2025, 08:24 AM
RE: Connect um330 and kc828 a16 - by admin - 10-16-2025, 10:43 AM
RE: Connect um330 and kc828 a16 - by gtd0916 - 11-18-2025, 08:18 AM
RE: Connect um330 and kc828 a16 - by admin - 11-18-2025, 10:13 PM
RE: Connect um330 and kc828 a16 - by gtd0916 - 01-07-2026, 04:07 AM
RE: Connect um330 and kc828 a16 - by admin - 01-07-2026, 07:17 AM
RE: Connect um330 and kc828 a16 - by gtd0916 - 01-08-2026, 01:15 AM
RE: Connect um330 and kc828 a16 - by admin - 01-08-2026, 01:44 AM
RE: Connect um330 and kc828 a16 - by gtd0916 - 01-08-2026, 06:21 PM
RE: Connect um330 and kc828 a16 - by admin - 01-09-2026, 12:52 AM
RE: Connect um330 and kc828 a16 - by gtd0916 - 01-09-2026, 04:37 AM
RE: Connect um330 and kc828 a16 - by gtd0916 - 01-22-2026, 09:37 AM
RE: Connect um330 and kc828 a16 - by admin - 01-22-2026, 12:18 PM
RE: Connect um330 and kc828 a16 - by gtd0916 - 01-23-2026, 12:35 AM
RE: Connect um330 and kc828 a16 - by admin - 01-23-2026, 01:14 AM
