KC868-A16 ethernet work with home assistant by ESPHome configure
#16
(01-11-2026, 12:53 PM)admin Wrote: updated yaml file for newest ESPHome.
  friendly_name: a16
    type: arduino
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk:
    pin: GPIO17
    mode: CLK_OUT
  phy_addr: 0
    address: 0x24
    address: 0x25
    address: 0x21
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      # Use pin number 0
      # One of INPUT or OUTPUT
      mode: OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_out_2
      # Use pin number 0
      mode: OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_in_1
      # Use pin number 0
      inverted: false
      pcf8574: pcf8574_hub_in_2
      # Use pin number 0
      inverted: false
  - platform: dht
    pin: 32
    temperature:
    humidity:
      name: "Living Room Humidity"
    update_interval: 60s
web_server:
  port: 80
yaml file download:
Hi! I used the updated yaml file. Mistake!
.txt   logs_kc868otopl_run (1).txt (Size: 154.72 KB / Downloads: 280)
RE: KC868-A16 ethernet work with home assistant by ESPHome configure - by Konstantin - 01-17-2026, 11:54 AM
