Relay board wiring error?
I've wired the controller up with a relay board but it acts a bit strange.
All the MOSFET LEDs are on at all the time.
The relay board uses 3 pins for power options. It is set to VCC JD-VCC.
The relays work when controlled from homeassistant through esphome with a little quirk. When homeassistant switches are off the relays turn on. So it works the opposite way.
The relay board gets its own power and ground.
Are the LEDs supposed to be on at all the time when a relay board is used ?
Is the opposite switching direction a configuration error or I wired something up incorrectly?
This is my esphome config for the board:
uart:
  - id: rs485
    tx_pin: GPIO13
    rx_pin: GPIO16
    baud_rate: 9600
remote_receiver:
    number: GPIO2
    ignore_strapping_warning: true
remote_transmitter:
    number: GPIO15
  carrier_duty_percent: 100%
  sda: GPIO4
  scl:
    number: GPIO5
  - id: inputs_1_8
    address: 0x22
    pcf8575: false
  - id: inputs_9_16
    address: 0x21
    pcf8575: false
  - id: outputs_1_8
    address: 0x24
    pcf8575: false
  - id: outputs_9_16
    address: 0x25
    pcf8575: false
      number: GPIO32
      number: GPIO33
      number: GPIO14
      pcf8574: inputs_1_8
    on_press:
      then:
        - switch.turn_on: out_y01
    on_release:
      then:
        - switch.turn_off: out_y01
      pcf8574: inputs_1_8
    on_press:
      then:
        - switch.turn_on: out_y02
    on_release:
      then:
        - switch.turn_off: out_y02
      pcf8574: inputs_1_8
    on_press:
      then:
        - switch.turn_on: out_y03
    on_release:
      then:
        - switch.turn_off: out_y03
      pcf8574: inputs_1_8
    on_press:
      then:
        - switch.turn_on: out_y04
    on_release:
      then:
        - switch.turn_off: out_y04
      pcf8574: inputs_1_8
      number: 4
    on_press:
      then:
        - switch.turn_on: out_y05
    on_release:
      then:
        - switch.turn_off: out_y05
      pcf8574: inputs_1_8
      number: 5
    on_press:
      then:
        - switch.turn_on: out_y06
    on_release:
      then:
        - switch.turn_off: out_y06
      pcf8574: inputs_1_8
      number: 6
    on_press:
      then:
        - switch.turn_on: out_y07
    on_release:
      then:
        - switch.turn_off: out_y07
      pcf8574: inputs_1_8
      number: 7
    on_press:
      then:
        - switch.turn_on: out_y08
    on_release:
      then:
        - switch.turn_off: out_y08
      pcf8574: inputs_9_16
    on_press:
      then:
        - switch.turn_on: out_y09
    on_release:
      then:
        - switch.turn_off: out_y09
    on_press:
      then:
        - switch.turn_on: out_y10
    on_release:
      then:
        - switch.turn_off: out_y10
    on_press:
      then:
        - switch.turn_on: out_y11
    on_release:
      then:
        - switch.turn_off: out_y11
    on_press:
      then:
        - switch.turn_on: out_y12
    on_release:
      then:
        - switch.turn_off: out_y12
      number: 4
    on_press:
      then:
        - switch.turn_on: out_y13
    on_release:
      then:
        - switch.turn_off: out_y13
      number: 5
    on_press:
      then:
        - switch.turn_on: out_y14
    on_release:
      then:
        - switch.turn_off: out_y14
      number: 6
    on_press:
      then:
        - switch.turn_on: out_y15
    on_release:
      then:
        - switch.turn_off: out_y15
      number: 7
    on_press:
      then:
        - switch.turn_on: out_y16
    on_release:
      then:
        - switch.turn_off: out_y16
      pcf8574: outputs_1_8
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: outputs_9_16
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
Thanks !
Relay board wiring error? - by Elgatoguiri - 01-22-2026, 02:58 PM
RE: Relay board wiring error? - by admin - 01-23-2026, 12:04 AM
RE: Relay board wiring error? - by Elgatoguiri - 01-30-2026, 02:39 PM
RE: Relay board wiring error? - by admin - 01-31-2026, 02:21 AM
