02-22-2026, 07:40 PM
(01-11-2026, 12:53 PM)admin Wrote: updated yaml file for newest ESPHome.
yaml file download:Code:esphome:
friendly_name: a16
type: arduino
sda: 4
scl: 5
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk:
pin: GPIO17
mode: CLK_OUT
phy_addr: 0
address: 0x24
address: 0x25
address: 0x21
address: 0x22
# Individual outputs
pcf8574: pcf8574_hub_out_1
# Use pin number 0
# One of INPUT or OUTPUT
mode: OUTPUT
inverted: false
pcf8574: pcf8574_hub_out_2
# Use pin number 0
mode: OUTPUT
inverted: false
pcf8574: pcf8574_hub_in_1
# Use pin number 0
inverted: false
pcf8574: pcf8574_hub_in_2
# Use pin number 0
inverted: false
- platform: dht
pin: 32
temperature:
humidity:
name: "Living Room Humidity"
update_interval: 60s
web_server:
port: 80
The framework uses type: arduino
Currently I have a board set up and in use over wifi. It uses type: esp_idf.
I want to change to ethernet. Do I have to change the type to arduino?
Thanks!
