HAv2 ESPHome
Hi Team,
I'm having trouble getting the external components working since the ESPHome changes.
I keep getting the below error when I try and compile. I have cleaned up all the build files etc and still no change.
INFO Unable to import component kc686_ha: No module named 'esphome.components.kc686_ha'
Failed config
kc686_ha: [source /config/esphome/device-191.yaml:72]
  Component not found: kc686_ha.
Below is my current config that won't compile.
  friendly_name: Switch - TR House Hub 1
  variant: esp32
    type: esp-idf
external_components:
  - source:
      type: git
      url: https://github.com/hzkincony/esphome-kc868-ha
      ref: v3.0.3
  encryption:
    key: "xxxxx"
  reboot_timeout:
    seconds: 120
ota:
  - platform: esphome
    password: "xxxxx"
wifi:
  ssid: !secret wifi_ssid
  fast_connect: on
  manual_ip:
    static_ip: 172.16.5.191
    gateway: 172.16.5.1
    subnet: 255.255.255.0
    dns1: 172.16.5.1
  ap:
    ssid: "Device-191 Fallback Hotspot"
    password: "xxxxx"
captive_portal:
web_server:
  port: 80
uart:
  - id: rs485
    tx_pin: GPIO13
    rx_pin: GPIO16
    baud_rate: 9600
  sda: GPIO4
  scl: GPIO5
  scan: True
  - id: inputs_1_8
    address: 0x22
  - id: inputs_9_16
    address: 0x21
  - id: outputs_1_8
    address: 0x24
  - id: outputs_9_16
    address: 0x25
kc686_ha:
  ### RS485 ###
  ### Master Bed INT  ###
  - platform: kc868_ha
    target_relay_controller_addr: 1 # Default value is 1, corresponds to the Target Relay Controller Addr parameter in HA485_Ctrl software
    switch_adapter_addr: 11 # Default value is 10, corresponds to the Switch Adapter Addr parameter in HA485_Ctrl software
    bind_output: 1 # Corresponds to the BindOutput parameter in HA485_Ctrl software
    name: "Master Bed Internal Button 1"
  ### Master Bed EXT  ###
    switch_adapter_addr: 12 # Default value is 10, corresponds to the Switch Adapter Addr parameter in HA485_Ctrl software
    bind_output: 7 # Corresponds to the BindOutput parameter in HA485_Ctrl software
    name: "Master Bed External Button 1"
    bind_output: 8 # Corresponds to the BindOutput parameter in HA485_Ctrl software
    name: "Master Bed External Button 2"
  ### Master WIR  ###
    switch_adapter_addr: 13 # Default value is 10, corresponds to the Switch Adapter Addr parameter in HA485_Ctrl software
    bind_output: 13 # Corresponds to the BindOutput parameter in HA485_Ctrl software
    name: "Master WIR Button 1"
  ### Master Ensuite ###
    switch_adapter_addr: 14 # Default value is 10, corresponds to the Switch Adapter Addr parameter in HA485_Ctrl software
    bind_output: 19 # Corresponds to the BindOutput parameter in HA485_Ctrl software
    name: "Master Ensuite Button 1"
    bind_output: 20 # Corresponds to the BindOutput parameter in HA485_Ctrl software
    name: "Master Ensuite Button 2"
    bind_output: 21 # Corresponds to the BindOutput parameter in HA485_Ctrl software
    name: "Master Ensuite Button 3"
  ### RS485 ###
  ### Master INT ###
    bind_output: 1
    name: "Master Bed Internal Indicator 1"
  ### Master EXT ###
    bind_output: 7
    name: "Master Bed External Indicator 1"
    bind_output: 8
    name: "Master Bed External Indicator 2"
  ### Master WIR ###
    bind_output: 13
    name: "Master WIR Indicator 1"
  ### Master Ens ###
    bind_output: 19
    name: "Master Ensuite Indicator 1"
    bind_output: 20
    name: "Master Ensuite Indicator 2"
    bind_output: 21
    name: "Master Ensuite Indicator 3"
HAv2 ESPHome - by rhinoperth - Yesterday, 06:46 AM
RE: HAv2 ESPHome - by admin - Yesterday, 11:01 AM
RE: HAv2 ESPHome - by rhinoperth - Yesterday, 11:11 PM
RE: HAv2 ESPHome - by admin - Today, 06:50 AM
