07-25-2026, 06:24 AM
friendly_name: b2
board: esp32-s3-devkitc-1
type: arduino
type: W5500
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
interrupt_pin: GPIO43
reset_pin: GPIO44
- id: bus_a
sda: 8
scl: 18
frequency: 400kHz
uart:
- id: uart_1 #RS485
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
tx_pin: 38
rx_pin: 39
- platform: uart
uart_id: uart_1
pin: 4
inverted: false
pin: 46
inverted: false
number: 6
number: 7
##pull-up resistance on PCB
number: 47
number: 48
number: 17
number: 40
ads1115:
- address: 0x48
- platform: ads1115
multiplexer: 'A0_GND'
gain: 6.144
resolution: 16_BITS
update_interval: 5s
- platform: ads1115
multiplexer: 'A1_GND'
gain: 6.144
update_interval: 5s
- platform: ads1115
multiplexer: 'A2_GND'
gain: 6.144
update_interval: 5s
- platform: ads1115
multiplexer: 'A3_GND'
gain: 6.144
update_interval: 5s
web_server:
port: 80
font:
- file: "gfonts://Roboto"
display:
- platform: ssd1306_i2c
i2c_id: bus_a
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.printf(0, 0, id(roboto), "KinCony B2");
B2-HA-Without-Tuya.txt (Size: 2.35 KB / Downloads: 6)
