T32M issue with Output 1
(05-06-2026, 06:49 AM)BarbaraVikuvis Wrote: I have recorded a short video to demo. Can you please advise if there is something special about output 1 or if there is a fault? All other outputs from 2 to 32 are ok, can turn them on and off.
Hey everyone, I've got a quick question about a video demo I just recorded. I'm seeing something odd with output 1 and wanted to get your thoughts.
Hi Barbara, from the earlier replies it looks like Output 1 isn’t supposed to behave differently from the other outputs. If it stays on even when switched off and a load confirms the same behavior, it sounds more like a MOSFET issue than a configuration problem.
I’d probably contact the seller first, especially if the board is still under warranty. Hopefully they can arrange a replacement or advise on the repair without having to modify the board yourself.
T32M issue with Output 1 - by Serg!o - 02-21-2026, 11:57 PM
RE: T32M issue with Output 1 - by admin - 02-22-2026, 12:08 AM
RE: T32M issue with Output 1 - by Serg!o - 02-23-2026, 07:55 AM
RE: T32M issue with Output 1 - by admin - 02-23-2026, 08:19 AM
RE: T32M issue with Output 1 - by BarbaraVikuvis - 05-06-2026, 06:49 AM
RE: T32M issue with Output 1 - by marktuan - 08-29-2026, 04:38 AM
