⚡ 40 Buttons, 36 Lighting Circuits & Home Assistant — How Would You Build It?
Hello @Admin,
Thanks for the details! That really helped me make progress on my equipment list.
Regarding the lighting, I’m having a bit of trouble finding that specific **"DC driver for DM4 dimmer controller."**
Do you have a KinCony part number for it, or perhaps another brand/model you recommend that is known to be compatible with the DM4? Otherwise, is there another alternative?
My current list is:
2 × A868-F24
1 × DM4 : 0–10V dimming
1 × Mean Well NDR-240-24 : 24V / 10A power supply
? x DC driver for DM4
4 x  phase DC (12-24V) 25A (radiateurs, ECS)
4 x RS485 SHT30
4 x KinCony Tiny Sensor SHT30
1 x 2A DC circuit breaker for protecting 24V boards and modules.
2 x 8A DC circuit breaker (1 per LED strips)
And of course, we add distribution blocks, connectors, terminal blocks, etc., to that.
Does an 800x600x250mm enclosure seem suitable to you?
I'm going to keep a GLEDOPTO ZigBee controller for my two RGB CCT LED strips.
Thanks for your help!
@Lulu
For the roller shutters, I only got my second quote this morning. I’ve decided to go with Somfy/SIMU RTS models and a small ESP32-based gateway. The extra cost for Somfy IO is significant. I’ll be getting the solar-powered versions.
RTS saves me 14 outputs on an F24 module, and the shutters will be self-powered—handy in the event of a power outage!
As for the wall switches, I’m still going to install standard push-buttons wired to the inputs of an A868-F24. I’ll set up a small PoE-powered ESP32 RTS module in the middle of the hallway for control, and the remote controls will end up in a drawer.
Thank you both for your help and your time. I really appreciate it!
RE: ⚡ 40 Buttons, 36 Lighting Circuits & Home Assistant — How Would You Build It? - by viko - 09-04-2026, 01:27 PM
