⚡ 40 Buttons, 36 Lighting Circuits & Home Assistant — How Would You Build It?
#21
If you have a single phase system, yes the Kincony N10 and the CT transformers will do the job. You can extend the cable, you will just need to solder.
The 1.5mm2 should be good for lighting. I *think* 0.5 mm2 will be ok for the rest, but I would check with the electrician.
RE: ⚡ 40 Buttons, 36 Lighting Circuits & Home Assistant — How Would You Build It? - by lulu01 - 09-07-2026, 08:29 PM
