K868-D8 Dimmer
take a photo how your wire. do you send command by ethernet cable? if it is, you should send command like "DIMMER-SEND-1,53" 1 is channel-1,53 is brightness.
DIMMER-SEND-01,xx is for RS485 port use.
if you want to change IP, find your board's IP, open browser to login, then you can change setting, just like login your router.
K868-D8 Dimmer - by opfinder - 12-13-2020, 04:39 PM
RE: K868-D8 Dimmer - by admin - 12-14-2020, 12:48 AM
RE: K868-D8 Dimmer - by opfinder - 12-14-2020, 11:48 PM
RE: K868-D8 Dimmer - by admin - 12-15-2020, 12:26 AM
RE: K868-D8 Dimmer - by opfinder - 12-15-2020, 10:00 AM
