CT Clamp Compatibility
#14
Thumbs Up
(08-09-2026, 08:52 PM)Stanb Wrote: I think you have sent me wrong type of sensors - current outputting ones.
Hi Kincony and everyone,
First - thank you very much to Kim at Kincony support!
Second - CT clamps are I received and have referred to in earlier posts work. I have tested them without mini-jack, then with mini-jack (my preferred variant due to assembly convenience) - they DO work.
I have conducted ARM co-processor firmware update, and after that (and eliminating my own other mistakes introduced in meantime) i received reliable readouts of the current.
Two hints on the upgrade:
1. Software to run the upgrade, with n60 in its name works for n30 as well (maybe for all the boards actually?)
2. for mac (apple silicon) users like me: the soft is Windows exe. You need for example Broadcom’s / VMware’s Fusion with Windows VM on it. Install n60xxxx.exe, pass through USB to use usb to 485 dongle, and it will work smoothly.
My work is still not finished, but i wanted to share thanks and reduce uncertainty for other users.
Best regards,
Stan
CT Clamp Compatibility - by threeofseven - 04-16-2024, 10:54 AM
RE: CT Clamp Compatibility - by admin - 04-16-2024, 12:18 PM
RE: CT Clamp Compatibility - by kiloptero - 06-22-2024, 11:12 PM
RE: CT Clamp Compatibility - by admin - 06-23-2024, 12:23 AM
RE: CT Clamp Compatibility - by Stanb - 08-08-2026, 10:43 PM
RE: CT Clamp Compatibility - by Stanb - 08-09-2026, 09:39 AM
RE: CT Clamp Compatibility - by admin - 08-08-2026, 11:56 PM
RE: CT Clamp Compatibility - by admin - 08-09-2026, 11:32 AM
RE: CT Clamp Compatibility - by Stanb - 08-09-2026, 02:52 PM
RE: CT Clamp Compatibility - by Stanb - 08-09-2026, 08:52 PM
RE: CT Clamp Compatibility - by Stanb - 10-24-2026, 12:20 PM
RE: CT Clamp Compatibility - by admin - 08-09-2026, 10:32 PM
RE: CT Clamp Compatibility - by Stanb - 08-16-2026, 01:12 PM
RE: CT Clamp Compatibility - by admin - 08-16-2026, 11:08 PM
RE: CT Clamp Compatibility - by admin - 10-25-2026, 12:21 AM
