KinCony 3-Wire PT100 Temperature Sensor Wiring Guide
  • Connect the two wires from the same end of the sensing element to the two “+” terminals, one wire to each terminal.
  • Connect the remaining wire to the “−” terminal.
  • No external power supply is required for the sensor.
The diagram uses two red wires and one white wire as an example. Follow your sensor’s wiring instructions to identify the correct wires.
KinCony 3-Wire PT100 Temperature Sensor Wiring Guide - by admin - 10-26-2026, 06:46 AM
