01-05-2022, 10:11 PM
1. yes, KinCony products support scenario mode. you can use "KinCony smart home " app for scene mode, just need internet, if you add KC868-COLB logical controller so that can use scene mode without internet, it's work in locally.
2. We suggest you chose the newest version KC868-H32BS, it output 32 channel DC12V, you can connect to Omron extend relay module (KC868-E16), so that will support MAX 16A, because KC868-E16 use relay by 16A/AC230V, also it support manual control if the KC868-H32BS is broken.
here is details of KC868-E16: https://www.kincony.com/din-rail-relay-module.html
here is video tour of KC868-E16: https://youtu.be/sSOE3ochczE
how to wire: https://www.kincony.com/images/kc868-e16...nstall.png
3. if you want to turn on/off each wall socket separately, let H32BS every channel output connect to one extend relay,the relay output connect with one socket. if you have " 10 lights, 15 wall switches, 30 wall sockets and 4 external curtains". so total relay is 10+15+30+4*2=63 channels. (every curtain motor need take two relays) so you can use 2pcs of KC868-H32BS, if you use multi-controller, just all use in one software window. if you have 15 wall switches, the "N" line can connected together, but "L" lines all from relay separately.
4. our wall switch have two version (just dry contact switch button all can use for KinCony's controller) a: Mechanical switch panel. b: touch glass switch panel.
type a. if you don't want to use 12V DC also can work, the dc12v just for LED indicator for relay state feedback.
type b. need have 12V DC power supply.
all switch panel just have two line for OPEN/CLOSE, then relay will be on/off, very easy, you can use CAT5 network cable, but this cable not for ethernet communication.
5. I suggest chose 2pcs of KC868-H32BS, 2pcs of KC868-E16, if want use scene mode, add 2pcs of KC868-COLB. the switch panel just chose color or style by yourself in our online store.
