Help to select proper controller kit
(02-06-2022, 10:39 AM)schel4ok Wrote: Look on attached pictures. Another seller offers PLC and IO modules, which can be connected directly to PLC using special connector on the right side of PLC. Or when you need IO modules far from PLC you can connect to PLC special bus coupler module via ethernet or RS485 and then connect to bus coupler many IO modules.
i think you can chose KC868-H32BS, it have 32 channel DI and 32 channel DO. support ethenret,wifi,RS232,RS485 modbus, support connect to KC868-COLB logical controller.
RE: Help to select proper controller kit - by admin - 02-06-2022, 01:40 PM
