Understand Configuration For Own Software
yes I can write a program but I would understand wich is the possibilities that I have ith you boards
at the moment my pc is connected to I/O module by rs485 , I would make the same with your module but with ethernet and the protocol is completly different
In my actual system I read every input and through  my software I can choose which out turn off or on.
I could send you some pictures of my software if you want to see
I would create an http server on a PC and set your cards in server mode to let them communicate with the PC, is this idea correct in your opinion?
I was also thinking of using the rs485 port of the KC868-COLB to control air conditions modbus devices but this too must be done through the PC which is connected through the LAN, is this possible?
RE: Understand Configuration For Own Software - by Dm81 - 02-09-2022, 12:39 PM
