  • 1 Vote(s) - 5 Average
Lesson29- How to use tasmota for KC868-A8 via PCF8574 IIC extend GPIO
(03-26-2022, 01:33 PM)admin Wrote: make sure your router have enable the DHCP.
router use correctly DHCP (same network than WiFi)
Using 'COM4' as serial port.
Connecting....
Detecting chip type... ESP32
Connecting......
Chip Info:
- Chip Family: ESP32
- Chip Model: ESP32-D0WDQ6 (revision 1)
- Number of Cores: 2
- Max CPU Frequency: 240MHz
- Has Bluetooth: YES
- Has Embedded Flash: NO
- Has Factory-Calibrated ADC: YES
- MAC Address: XXXXXXXXXX
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
- Flash Size: 4MB
- Flash Mode: dout
- Flash Frequency: 40MHz
Erasing flash (this may take a while)...
Chip erase completed successfully in 16.0s
Flash will be erased from 0x00001000 to 0x00005fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x0000e000 to 0x0000ffff...
Flash will be erased from 0x00010000 to 0x00158fff...
Compressed 17104 bytes to 11191...
Writing at 0x00001000... (100 %)
Wrote 17104 bytes (11191 compressed) at 0x00001000 in 0.5 seconds (effective 274.8 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 129...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (129 compressed) at 0x00008000 in 0.1 seconds (effective 464.4 kbit/s)...
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 682.9 kbit/s)...
Compressed 1346464 bytes to 910725...
Writing at 0x00010000... (1 %)
Writing at 0x000194b4... (3 %)
Writing at 0x000218ed... (5 %)
Writing at 0x0002a314... (7 %)
Writing at 0x00033359... (8 %)
Writing at 0x0003e87c... (10 %)
Writing at 0x00045c91... (12 %)
Writing at 0x0004b189... (14 %)
Writing at 0x000502ce... (16 %)
Writing at 0x000551d9... (17 %)
Writing at 0x0005a51a... (19 %)
Writing at 0x0005fe5e... (21 %)
Writing at 0x000651b2... (23 %)
Writing at 0x0006a376... (25 %)
Writing at 0x0006f678... (26 %)
Writing at 0x00074696... (28 %)
Writing at 0x00079774... (30 %)
Writing at 0x0007ed2e... (32 %)
Writing at 0x00083ad8... (33 %)
Writing at 0x00088d43... (35 %)
Writing at 0x0008eb99... (37 %)
Writing at 0x0009430e... (39 %)
Writing at 0x0009a08b... (41 %)
Writing at 0x0009f878... (42 %)
Writing at 0x000a53e6... (44 %)
Writing at 0x000aab60... (46 %)
Writing at 0x000b0589... (48 %)
Writing at 0x000b62a4... (50 %)
Writing at 0x000bbbfc... (51 %)
Writing at 0x000c1729... (53 %)
Writing at 0x000c76a8... (55 %)
Writing at 0x000cc8ee... (57 %)
Writing at 0x000d1e33... (58 %)
Writing at 0x000d70fd... (60 %)
Writing at 0x000dc569... (62 %)
Writing at 0x000e182c... (64 %)
Writing at 0x000e69da... (66 %)
Writing at 0x000ebb47... (67 %)
Writing at 0x000f11f7... (69 %)
Writing at 0x000f70c5... (71 %)
Writing at 0x000fc686... (73 %)
Writing at 0x0010185e... (75 %)
Writing at 0x00106bd6... (76 %)
Writing at 0x0010c0e8... (78 %)
Writing at 0x0011174d... (80 %)
Writing at 0x00116f46... (82 %)
Writing at 0x0011cd25... (83 %)
Writing at 0x0012277c... (85 %)
Writing at 0x00128a67... (87 %)
Writing at 0x001314aa... (89 %)
Writing at 0x00139caf... (91 %)
Writing at 0x0013ed62... (92 %)
Writing at 0x00144d86... (94 %)
Writing at 0x0014a71c... (96 %)
Writing at 0x0014fbe4... (98 %)
Writing at 0x0015547b... (100 %)
Wrote 1346464 bytes (910725 compressed) at 0x00010000 in 21.1 seconds (effective 510.1 kbit/s)...
Leaving...
Hard Resetting...
Hard resetting via RTS pin...
Done! Flashing is complete!
Showing logs:
[15:53:06]
[15:53:06]00:00:00.003-218/71 HDW: ESP32-D0WDQ6
[15:53:06]./components/esp_littlefs/src/littlefs/lfs.c:1071:error: Corrupted dir pair at {0x0, 0x1}
[15:53:07]00:00:00.404-216/71 UFS: FlashFS mounted with 312 kB free
[15:53:07]00:00:00.411-216/71 CFG: Use defaults
[15:53:08]00:00:00.567 QPC: Reset
[15:53:08]00:00:00.609 BRY: Berry initialized, RAM used=3294
[15:53:08]00:00:00.622 BRY: no 'preinit.be'
[15:53:08]00:00:00.632 Project tasmota - Tasmota Version 10.0.0.3(tasmota)-2_0_1(2021-11-14T21:44:07)
[15:53:08]00:00:00.647 BRY: no 'autoexec.be'
[15:53:08]00:00:00.924 WIF: WifiManager active for 3 minutes
[15:53:09]00:00:01.231 HTP: Web server active on tasmota-XXXXX with IP address 192.168.4.1
At this point of the tutorial, ethernet doesn't work : no led blink/solid
RE: Lesson29- How to use tasmota for KC868-A8 via PCF8574 IIC extend GPIO - by JulienR - 03-26-2022, 01:59 PM
