05-12-2022, 01:35 PM
Tasmota for A16 is no problem, you can download BIN firmware from our forum.
But tasmota support total 32 channel (DI+DO) , you can use 32 channel output by tasmota or 16 input +16 output by tasmota, but can't use 32 input + 32 output by tasmota.
if you want to use 32 input + 32 output, i suggest you use ESPHome, you can enable ESPHome 's web service function, so that can work without home assistant, just use KC868-A32 work as a web service, just connect with ethernet cable, then you can use web browser login and turn ON/OFF every relay output and monitor every input ports.
also you can set input trigger relay output, such as use input connect with push button manual control relay output without network, it's work in locally.
