[Arduino IDE demo source code for KC868-E16S]--#05-KC868-E16S-LAN8720_UDP
Thumbs Up
/*www.kincony.com */
/* KC868-E16S CODE OF LAN8720-UDP */
#include <ETH.h>
#include <WiFiUdp.h>
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN   18
#define ETH_TYPE       ETH_PHY_LAN8720
#define ETH_CLK_MODE   ETH_CLOCK_GPIO17_OUT
WiFiUDP Udp;                      //Create UDP object
unsigned int localUdpPort = 4196; //local port
IPAddress local_ip(192, 168, 1, 200);
IPAddress gateway(192, 168, 1, 1);
IPAddress dns(192, 168, 1, 1);
void setup()
  Serial.println();
  ETH.begin(ETH_ADDR, ETH_POWER_PIN, ETH_MDC_PIN, ETH_MDIO_PIN, ETH_TYPE, ETH_CLK_MODE); //start with ETH
  // write confir for static IP, gateway,subnet,dns1,dns2
  Serial.println("Connected");
  Serial.print("IP Address:");
  Udp.begin(localUdpPort); //begin UDP listener
void loop()
  int packetSize = Udp.parsePacket(); //get package size
  if (packetSize)                     //if have received data
    char buf[packetSize];
    Udp.read(buf, packetSize); //read current data
    Serial.println();
    Serial.print("Received: ");
    Serial.println(buf);
    Serial.print("From IP: ");
    Serial.println(Udp.remoteIP());
    Serial.print("From Port: ");
    Serial.println(Udp.remotePort());
    Udp.beginPacket(Udp.remoteIP(), Udp.remotePort()); //ready to send data
    Udp.print("Received: ");
    Udp.write((const uint8_t*)buf, packetSize); //copy data to sender buffer
    Udp.endPacket();            //send data
.zip   KC868-E16S-LAN8720_UDP.zip (Size: 1.11 KB / Downloads: 664)
[Arduino IDE demo source code for KC868-E16S]--#05-KC868-E16S-LAN8720_UDP - by KinCony Support - 05-17-2022, 01:28 AM
